Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Platinum Member Henri88's Avatar
    Join Date
    Nov 2009
    Posts
    583
    Northern N.B.
    2008 2305 jd
    Default Re: Plowing some powder with the 1026R
    Quote Originally Posted by rockshaft View Post
    Actually for the first half i was nursing it in low range- to allow it to warm up, then went into high range.
    Ok, that makes more senses. Sure seems like an easy task for the little bugger.
    How could you be told I was french?
    4' Howse rotary cutter, mid mount lawnmower, f.e.loader, pallet forks, tiller, cultivator, middle buster, snowblower, grass-sweeper, quick hitch, trailer hitch, jodale-perry cab
  2. #12
    Gold Member
    Join Date
    Nov 2012
    Posts
    457
    mansfield,Il
    john deere
    Nice video ,nice place , nice tractor . I really like your tractor shed , what is it ? You have some nice mods to your tractor . Counterweight with sleeve hitch , flasher protection , you do nice work . What is hanging off the right floorboard ?
  3. #13
    Elite Member Don87's Avatar
    Join Date
    May 2010
    Posts
    3,781
    SW Pa.
    Massey Ferguson GC2400
    Quote Originally Posted by kevin37b View Post
    Should be the plugs for the hydraulic lines. They are color coded.
    Don
    MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
  4. #14
    Veteran Member Dutch445's Avatar
    Join Date
    Aug 2001
    Posts
    1,842
    Upstate NY
    JD X585
    rockshaft it looks like a yellow extension cord running up to the angling actuator
    where did you mount the base of the actuator? can't really see from the pictures,
    but it looks like maybe on that brass colored steel rod going between the bucket mount paddles?
    nice video!
    JD X585 with 45 loader, 3ph, 62C deck, 47SB, 54 blade, Soft Cab. JD F525 with 48". JD 4X2 gator. JD T23 trimmer
    JD CS56 and CS36 saws. JS35 WB mower.
  5. #15
    Gold Member rockshaft's Avatar
    Join Date
    Feb 2012
    Posts
    258
    Sterling, AK
    1026R
    Thanks. Sometimes the cost (time/$$$) is high enough for home built stuff that it hardly makes sense, but it can be rewarding in other ways. For me, the freight cost for pro-manufactured goods from the lower 48 is usually the largest factor.
  6. #16
    Join Date
    Feb 2012
    Posts
    258
    Sterling, AK
    1026R
    Quote Originally Posted by Don87 View Post
    Don87 is right. SCV plugs
  7. #17
    Join Date
    Feb 2012
    Posts
    258
    Sterling, AK
    1026R
    Quote Originally Posted by Dutch445 View Post
    nice video!
    Yes, JD Yellow HD extension cord for FEL accessory control.
    The base of the actuator is on a bracket attached to the FEL multi-mount and plow base plate.
    Maybe this pic shows a little better. Its not pretty, as I can't paint all the bare metal parts until the summer when it warms enough.
  8. #18
    Join Date
    Feb 2012
    Posts
    258
    Sterling, AK
    1026R
    The shed is a Shelter Logic garage-in-a-box, its the SUV model that has a tall door.
  9. #19
    Elite Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    4,866
    Kasilof, Alaska
    JD 5075M; JD 110 TLB; Ford Ferguson 9N: JD X300R
    Very nice fabrication work! Nice pics! The latest snow dumps have been heavy, wet crap! Dang! I've been getting complacent with the cold temps and the fluffy powder snow that came with that.. Just drive back and forth a few times and build up a "road base"! Can't do that with 8" of sludge.
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
  10. #20
    Join Date
    Feb 2012
    Posts
    258
    Sterling, AK
    1026R
    Quote Originally Posted by AKfish View Post
    AKfish
    Yeah, complacency can be a rude biatch. We're fortunate to get mostly powder here, but if you wait to deal with it too long and it warms up- it seems to suck up all the moisture from the air. Our daily driver doesn't like that deeper wet heavy stuff.
Similar Threads
  1. Eastwood Powder Coating
    By Scotty Dive in forum Build-It Yourself
    Last Post: 11-30-2012, 09:35 AM
  2. Is old black powder safe?
    By Pilot in forum Rural Living
    Last Post: 05-08-2012, 08:48 AM
  3. Powder Coating question
    By Furu in forum Build-It Yourself
    Last Post: 03-18-2012, 05:34 PM
  4. Painting over powder coat
    By caseyvand in forum Parts/Repairs
    Last Post: 03-15-2010, 09:30 PM
  5. stiptic powder
    By Soundguy in forum Safety
    Last Post: 06-28-2004, 01:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
