Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    EdC
    EdC is offline
    Gold Member
    Join Date
    Feb 2007
    Posts
    320
    Eastern Washington
    JD 2320
    Default Re: Jd 2320
    Sven
    Momentum is your friend. I have loaded R4s and find they do pretty well as long as I keep the momentum up. I can push snow for more than one hundred feet before I have so much snow piled up in front I lose momentum and have to move it to the side to dump. Of course on ice it is much less. When I push a lot of snow and the tires are on ice the rear of the tractor really wants to go sideways. My driveway goes up a gentle hill and while I can tell it is there the tractor keeps on going. Usually I have a rear blade on but sometimes if it is near freezing a rake works better to bring some of my gravel to the surface. Good luck during the storm, it sounds like a doozy.
    Ed
    JD 120, JD 2320, 200CX FEL, RB2060 Rear blade
  2. #12
    Banned
    Join Date
    Feb 2013
    Posts
    101
    east coast
    2012 JD 3720 deluxe cab
    Default Re: Jd 2320
    Quote Originally Posted by megotatractor View Post
    What type of tires? Turf or industial? I've heard the latter is useless in snow and I know from experience the turfs aren't much use in snow. Filled tires should be enough weight for snow. Chains would boost traction more than weight.
    i think you may have accidently worded this wrong. Industrials have no traction in snow. Turfs are superior. Industrials have no grip whatsoever. I suppose if you ran around in 12 inches of snow with the blade in the air they would be superior but once you put the blade down and remove the snow and are stuck with a thin film ofsnow, you lose all traction like drag racing slicks in the rain. at that point turfs reign supreme
  3. #13
    Platinum Member Henri88's Avatar
    Join Date
    Nov 2009
    Posts
    583
    Northern N.B.
    2008 2305 jd
    Default Re: Jd 2320
    Quote Originally Posted by chin View Post
    I though he had it right, but then again I'm french.
    How could you be told I was french?
    4' Howse rotary cutter, mid mount lawnmower, f.e.loader, pallet forks, tiller, cultivator, middle buster, snowblower, grass-sweeper, quick hitch, trailer hitch, jodale-perry cab
  4. #14
    Join Date
    Aug 2007
    Posts
    185
    New Brunswick
    2008 JD 2320
    Default Re: Jd 2320
    Saying R4's have no traction in snow is not correct either. I agree that Turfs are a better choice, but I have R4's that are not loaded and have a very steep driveway and manage just fine. If they had no traction, I would not be able to deal with my 800 ft long very steep driveway. Would I prefer turfs? Yes! But I don't have turfs and it is not bad enough for me to go and spend the $1K or so on getting them. Maybe when I start mowing this will change....
    On ice, the R4's have very little traction but to be honest the only tire that will be good on ice is a tire with a chain on it...
    2008 John Deere 2320 / CX200 Loader / SB1154 Rear Blower / RB2072 72" Rear Blade
    (Sold) 08 Kubota BX25 /54" MMM / 48" LP BB/ Bro-Tek skid plates / Bro-Tek Thumb/
  5. #15
    Silver Member topstoy's Avatar
    Join Date
    Nov 2009
    Posts
    104
    Ferndale, WA/Tonasket, WA
    JD 2520 / Ford 1710
    Default Re: Jd 2320
    I agree with Mac as my driveway is about 1000 feet and most of it uphill and managed just fine pushing 8" of snow with my FEL using the R4's. Apparently there are some folks on here that have very little experiance and making big claims.
  6. #16
    Veteran Member GPintheMitten's Avatar
    Join Date
    Sep 2009
    Posts
    1,047
    Flushing, Michigan
    Kubota B2620
    Default
    Well, we'be all chimed in, and the storm has come and gone. How did it go for you, Sven?
  7. #17
    Banned
    Join Date
    Feb 2013
    Posts
    101
    east coast
    Default Re: Jd 2320
    Quote Originally Posted by topstoy View Post
    . your right, i dont know what im talking about becuase it doesnt snow upstate new york. Sorry I hurt your feelings about your r4 tire
  8. #18
    Veteran Member yelbike's Avatar
    Join Date
    Nov 2011
    Posts
    1,088
    Near Winnipeg, Mb, Canada
    John Deere 2305, 2320,Z465
    Default Re: Jd 2320
    I have both turf and R4s. Sorry but turfs seem much much better to me in snow. I would change over if it wasn't for the fear of having the opposite problem tilling in the summer. I spend way more time tilling then I do snow blowing. I have about 600hr total recent operating time to make that claim.
    Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
  9. #19
    Member
    Join Date
    Feb 2011
    Posts
    43
    Middletown CT
    John Deere 2720
    Default Re: Jd 2320
    I have a 2720 with R4. I just went though the 2013 Blizzard in CT. Where I live on top of a hill. I got over 4 feet of snow and drifts over 7 feet high. The R4 in 4wd worked fine. I have a ballst box onthe rear with 350lbs. Just enought to conter the weight of the 54' blower. I had one issue on Sunday when I went to far in bottwm of a 6 foot pack snow bank that the street plow left infront of a driveway. The bank fell between the tractor and blower. I tried to back up but the weight of the snow burying the front was to much. I was also on a layer of ice. Dug out the snow between the blower and the tractor and it backed out without any issues. I was a little more careful after that. I do have chains, but in 3 years i have never had to use them.
  10. #20
    Member
    Join Date
    Feb 2011
    Posts
    43
    Middletown CT
    John Deere 2720
    Default Re: Jd 2320
    Here is a picture of my 2720. I working on making the cab myself. The front, roof and back are done. still working one the doors. The roof, front and back come off is less then 5 minutes.
    Nice not to have the snow flying in my face. In this pic I finished my driveway and the tractor is in the street which had not been cleared yet.
Similar Threads
  1. MY NEW 2320 IS HERE!!!!
    By JD230511 in forum John Deere Buying/Pricing
    Last Post: 02-27-2012, 07:49 AM
  2. Kubota 2320 / JD 2320
    By Wabiv in forum Buying/Pricing/Comparisons
    Last Post: 11-04-2009, 05:08 PM
  3. 2320
    By jd140400 in forum John Deere Owning/Operating
    Last Post: 02-09-2008, 10:47 PM
  4. My new 2320
    By Hard in forum Kubota Buying/Pricing
    Last Post: 08-27-2006, 10:09 AM
  5. 2320 now you see it...
    By megotatractor in forum John Deere Buying/Pricing
    Last Post: 06-30-2006, 10:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
