Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Member
    Join Date
    Feb 2011
    Posts
    43
    Middletown CT
    John Deere 2720
    Default JD 2720 Hydralic Fluid & Snow Blower
    I have a 2011 2720 JD with a 54 Snow Blower. This weekend Connecticut received a big snow storm. I always check fluids very closely before heading out into such a large storm. Some of the snow drifts I had to move were over 7 feet tall. JD really should increase the height of this front mounted blower.
    Anyway, I always check Transmission/Hydraulic fluid by both the site glass and the dip stick. When I stated out the site glass was almost to the top (just a small bubble) and the dip stick showed about 1/8 inch below the FULL mark.
    8 hours of Run time later, and 4 hours of cooling off, parked in the same spot in the garage the site glass is now in the middle and the dip stick shows about 3/8 inch below the FULL mark. Based on 典op off experience I estimate about シ of a quart disappeared during that 8 hours of run time.
    I looked over the entire tractor and could not find any evidence of a fluid leak. I still have the break oil in the transmission, I just approaching 50 hours and will be doing the change in the spring.
    However I have never heard of a machine or owned a machine that *sed Transmission oil.
    Anyone have any ideas where the oil went?
    I second thing I noticed when blowing snow hard (chute going full bore, I wish the chute was bigger) occasionally I smell something getting hot, almost a burning smell, I back off for a little bit and the smell disappears. I first noticed this smell with the tiller last fall and I thought it was the clutch on the tiller. Now I am think it is something on the tractor.
    Has anybody else had this experience?
    Attached Thumbnails Attached Thumbnails JD 2720 Hydralic Fluid & Snow Blower-need-bigger-blower-jpg
  2. #2
    Join Date
    Aug 2007
    Posts
    211
    New Brunswick
    2008 JD 2320
    Default Re: JD 2720 Hydralic Fluid & Snow Blower
    Find a scenario to measure the oil in the glass without any different variables and you will then know if you have a leak.
    I check mine only when cold before start up and it is always in the same spot with a small bubble at the top. Check it again when stone cold....
    2008 John Deere 2320 / CX200 Loader / SB1154 Rear Blower / RB2072 72" Rear Blade
    (Sold) 08 Kubota BX25 /54" MMM / 48" LP BB/ Bro-Tek skid plates / Bro-Tek Thumb/
  3. #3
    Join Date
    Apr 2011
    Posts
    541
    John Deere 2720
    I have a 2720 & 54" blower also. Was your blower resting on the floor both times? If your blower was raised and the chute turned all the way it could result in some extra consumption by the two front-mounted hydraulic cylinders?
    My sight glass is all over the place. One time it's full the next empty. It seems you must have the tractor perfectly level and leave it sit a long time for an accurate measurement. Which for your example, 4 hours would seem plenty.
  4. #4
    Member
    Join Date
    Feb 2011
    Posts
    43
    Middletown CT
    John Deere 2720
    Quote Originally Posted by jgayman View Post
    I am aware the Hydralic cylinders draw from the oil volume. I always park the tractor with snowblower on the floor , chute turned to the right. 3pt hitch with weight box up all the way. Therefore I eally do fell I am performing a proper comparison. I have also read to only check when cold.
  5. #5
    Gold Member PCABE5's Avatar
    Join Date
    Oct 2007
    Posts
    291
    NW Wisconsin
    JD 2520
    Default
    Quote Originally Posted by 70stang View Post
    Shouldn't the 3 pt hitch be lowered to check fluid level? I think the manual says to lower everything.
    2012 JD 2720 | 72" MMM | Curtis Hard Cab | 200CX FEL 73" bucket | JD 72" Rr Blade | Michigan Suspension Seat | SpeeCo Q-Hitch | JD Ballast-Box | 5ft King Kutter Brush Cutter |
  6. #6
    Member
    Join Date
    Feb 2011
    Posts
    43
    Middletown CT
    John Deere 2720
    Quote Originally Posted by PCABE5 View Post
    Yes, the manaul says lowered for an accurate check. Personnelly I have not seen the height of the 3 point to make much difference in fluid levels.
    The FEL cylinders make a big differecnce.
    However my point I am check the oil in the same position everytime I use the tractor.
    This past weekends snow storm the tractor worked hard and I suddenly saw a difference in the fluid level.
    The JD manaul does not say anything about the dipstick, however I think the dipstick is much more accurate then the site glass.
    The site glass is only good when the tractor has sat for a lenghty period of time.
  7. #7
    Join Date
    Apr 2011
    Posts
    541
    John Deere 2720
    I agree. I'm not sure why the manual makes no mention of the dipstick. I initially discovered it from a YouTube video. Then again, given the difficult access of the dipstick perhaps JD wanted to avoid injuring the hands and fingers of new owners. One of my pet projects once the weather warms up is to extend the handle slightly on mine so it becomes usable.
  8. #8
    Platinum Member Henri88's Avatar
    Join Date
    Nov 2009
    Posts
    759
    Northern N.B.
    2008 JD 2305, 800hr
    Agreed, you don't have to worry about it. Your oil is not going no where, unless you have a leak, and this, you would notice it pretty quickly. As jgayman have said, sometime it will be either top, middle or bottom of the site glass.
    Henri
    How could you be told I was french?
    Rotary cutter 4' Howse , mid mount mower 54'' , f.e. loader 200CX , tiller RT1150 Frontier , cultivator PC1001 Frontier , middle buster PM1001 Frontier , JD 47'' front snowblower , pallet forks , 4' boxblade Agriease , grass-sweeper , quick hitch Speeco , trailer hitch , cab Jodale-Perry , trailer 16' galvanized Easy-Hauler ,
  9. #9
    Gold Member BuilderML's Avatar
    Join Date
    Nov 2012
    Posts
    479
    Tolland, CT
    CCY SX3100
    Hi 70stang,
    I have a ccy sx3100 twin model to you jd2720. After reading about the dipstick for the hydro fluid i went to take a look at my tractor and couldn't see anything.
    My manual only states to check via site glass. Could you tell me where the dipstick is on your model or take a pic for me. Don't think i have one but would be nice to know for sure. That was one **** of a storm we got this past weekend. 8 hours of driveway clean up!!!!
    Thanks for any help you can give.
  10. #10
    Join Date
    Nov 2012
    Posts
    479
    Tolland, CT
    CCY SX3100
    Hi 70stang,
Similar Threads
  1. 2720 & 47 Snow Blower
    By chevy in forum John Deere Owning/Operating
    Last Post: 01-16-2013, 10:20 PM
  2. Front End Snow Blower for 2720..how much$$
    By brian22 in forum John Deere Owning/Operating
    Last Post: 11-19-2011, 11:33 AM
  3. snow blower pump & motor
    By wrench monkey in forum Hydraulics
    Last Post: 02-09-2011, 02:09 PM
  4. Snow Snow blower gear box fluid
    By 16valex in forum Kubota Owning/Operating
    Last Post: 12-07-2010, 01:52 PM
  5. Snow NEW SNOW BLOWER & SNOW STORM
    By RADIUM in forum New Holland Owning/Operating
    Last Post: 05-29-2009, 09:11 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
