Results 1 to 7 of 7
  1. #1
    Gold Member
    Join Date
    Oct 2000
    Posts
    412
    NH
    John Deere 3720 Cab Tractor
    Default 3720 Cab: Front Drive Shaft
    I have a question about my front drive shaft. I lost a roll pin that goes into the coupler that slips over the spline that powers the MFWD.
    So my question is, is there a hole on the spline that this roll/spring goes through? Or is the hole located on the actual driveshaft itself? Or is the pin only used as a spacer between the two splines...
    The night of the blizzard, I lost my 4wd, I was very scared I screwed up the front axle.. But the next day I realized it was the shaft itself not being able to slip over the MFWD spline. Then I noticed the rear coupler near the transmission has a pin through the center, and the front coupler is missing a pin, only a bare hole is showing... Has this happened to anybody else?
  2. #2
    Gold Member
    Join Date
    Nov 2008
    Posts
    302
    minnesota
    JD
    Default Re: 3720 Cab: Front Drive Shaft
    the pin is used as a spacer as you asked. it centers the coupler on the two shafts. If you didn't lose the coupler, just get a new roll pin and away you go.
    3520
  3. #3
    Gold Member
    Join Date
    Oct 2000
    Posts
    412
    NH
    Default
    Thanks... Hoping that is all it is... If not maybe a cable adjustment on the lever... I can position the driveshaft by hand and it will bite into 4wd mode... But it won't stay... I was able a few times with the wheels off the ground to pop it in and put of 4wd... But once I get using the machine, it jostles free again... The splines look okay... Definitely not completely stripped... Any other ideas?? Under closer examination it looks like the pins are intact...
  4. #4
    Gold Member
    Join Date
    Oct 2000
    Posts
    412
    NH
    Default
    One last stupid question... When you throw the lever into 4wd, is it just turning the turning the spline on? Or is it throwing the driveshaft forward to engage with the front spline?
    The shaft isn't supposed to move back and forth? Correct?
  5. #5
    Join Date
    Dec 2005
    Posts
    622
    Central Maine
    The engagement occurs in the transmission. The coupling and shaft do not move back and forth.
  6. #6
    Gold Member
    Join Date
    Oct 2000
    Posts
    412
    NH
    Default
    Quote Originally Posted by charleyfarmall View Post
    Thanks!!!!!
  7. #7
    Elite Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    4,869
    Kasilof, Alaska
    JD 5075M; JD 110 TLB; Ford Ferguson 9N: JD X300R
    KennedyDiesel had more/less the same problem. If the pin dropped out - there might be just enough wear that the OEM pin is loose enough to just work it's way out of the hole. I'd try to use a split-roll pin that's a bit larger and drive that into the hole.
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
Similar Threads
  1. Front Drive Shaft
    By wbvs58 in forum Kubota Owning/Operating
    Last Post: 04-20-2012, 04:12 AM
  2. 7200 front drive shaft
    By boatn in forum Cub Cadet Yanmar & CUTs
    Last Post: 07-16-2009, 11:14 AM
  3. Front drive shaft problems
    By Tdog in forum Kubota Owning/Operating
    Last Post: 07-31-2008, 10:29 PM
  4. BX front drive shaft
    By ericbx1500 in forum Kubota Owning/Operating
    Last Post: 04-28-2007, 09:58 PM
  5. Front drive shaft noise
    By B2400 in forum Kubota Owning/Operating
    Last Post: 06-26-2004, 09:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
