Results 1 to 5 of 5
  1. #1
    Member
    Join Date
    Feb 2012
    Posts
    45
    Wisconsin
    2013 JD X738
    Default Cab x738 Need more info
    Need a little more info if anyone can help ? Soft sided cab with a hard roof : Does anybody Remove these during the summer season ? I only want to use it in the winter. refering to a X728 now 38, size tractor. How much trouble is it ?
  2. #2
    Elite Member bigtiller's Avatar
    Join Date
    Feb 2006
    Posts
    3,424
    central Iowa
    JD 2720
    Default Re: Cab x738 Need more info
    I took the cabs off every spring of my 455's and X495's years ago but they were hard-sided ROPS cabs from Cozy. I took the doors off, unbolted everything, called 2 friends and we lifted it off by hand. It was more awkward than heavy. The entire process took me less than an hour.
    HAVE FUN
    Life is easier when you plow around the stumps.
    2720
  3. #3
    Platinum Member Henri88's Avatar
    Join Date
    Nov 2009
    Posts
    759
    Northern N.B.
    2008 JD 2305, 800hr
    I remove mine every spring. The initial installation took a full day, but now it takes me half a day when I'm alone. I use a pulley system to help out. Keep in mind that my cab is ROPS so I have to remove the one on the tractor first. It also have the electrical and hoses connection for the wiper, lights and the heather. Henri
    Cab x738  Need more info-dscf6619-jpgCab x738  Need more info-dscf6602-jpg
    Henri
    How could you be told I was french?
    Rotary cutter 4' Howse , mid mount mower 54'' , f.e. loader 200CX , tiller RT1150 Frontier , cultivator PC1001 Frontier , middle buster PM1001 Frontier , JD 47'' front snowblower , pallet forks , 4' boxblade Agriease , grass-sweeper , quick hitch Speeco , trailer hitch , cab Jodale-Perry , trailer 16' galvanized Easy-Hauler ,
  4. #4
    Join Date
    Jun 2011
    Posts
    88
    UPSTATE new york
    I have a 728 along with the same cab you have and remove it every spring...very simple, about 20 min. job. flip it upsidedown on a carpet covered pallet and done..............my question is will this same cab work on the new style tractor??????????
  5. #5
    Member
    Join Date
    Feb 2012
    Posts
    45
    Wisconsin
    2013 JD X738
    Found out that the X738 / 2013 does not use the same cab as a X728 / 2012. The hood is slightly different and has a new style vent system for the radiator. A cab would block these air vents. My dealer is looking into this. My new tractor should be here towards the of the month. May have to wait for somebody to come up with a new style cab.
Similar Threads
  1. Question on cabs for X738
    By jbgood in forum John Deere Owning/Operating
    Last Post: 02-22-2015, 09:23 PM
  2. x738 Brush Bar
    By jbgood in forum John Deere Lawn & Garden
    Last Post: 02-24-2013, 03:41 PM
  3. 2013 X738
    Last Post: 02-07-2013, 10:26 PM
  4. Need some info on JD Cab Radio ideas....
    By nmu98 in forum John Deere Owning/Operating
    Last Post: 11-30-2008, 10:57 PM
  5. 4400 Cab parts info
    By DDT in forum Customization
    Last Post: 12-13-2002, 10:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
