Results 11 to 20 of 34
03-05-2013, 10:09 PM #11
Re: Ballast for a 59 front mount snowblower
That's the other lesson I've learned... when you do see something come up and you've been wanting it, you have to jump on it immediately or it's gone. I drove 400 miles round trip to get this blower. The farthest I've ever traveled for a piece of equipment was from NW Missouri to Ypsilanti, MI... that was the closest 70A loader I'd seen for a reasonable price in over a year of looking.
03-05-2013, 10:53 PM #12
i did find a 59 forsale not to far from me, but im going to assume it will be to big for me, do you think id be able to compensate with a lower speed?
1988 John Deere 755
52 Loader
JD 59 Front mount snowblower
60" MMM
MFWD
48" JD Model 40 tiller
Craftsman YS4500
22 Hp Briggs & Stratton
03-05-2013, 11:13 PM #13
I don't think you'd be happy with it in the long run. Deere only intended the 59 to be use on the 855 and 955 of the x55 series tractors. I don't think the 755 would be too happy with 59... just not enough PTO horsepower IMO. I actually see more 47's come up around here than I do 59's. If the deal is ok, you could always try it and see and if it was just too much blower for the 755, you could always resell it... but then you have your $$$ tied up in it until you can sell it. If it were me, I would not attempt it and hold out for the 47.
03-06-2013, 12:24 AM #14
On second thought... I did a little more looking into the 47" blower and both the 47 and the 59 have a 16" diameter impeller and 16" diameter auger. Looks like the only major difference is the 59 is a foot wider and and 50lbs. heavier. Not sure how the 755 would handle the 59, but perhaps it would work by just slowing down a little on travel speed. Since the 755 uses smaller front tires than the 955, everything would be closer to the ground, so you wouldn't be able to lift the blower as high off the ground. I don't know how much total lift you'd get, but it may be enough. If you decided to give it a try, let us know how it turns out.
If it doesn't work out, you could cut down each of the auger shafts 6" and narrow the housing to make it a 47... but that sounds like a fair amount of work.
03-06-2013, 08:36 AM #15
- Join Date
- Aug 2009
- Posts
- 917
- Location
- Kansas
- Tractor
- John Deere 755 purchased new in 1993
I would not expect the lift height to be an issue since the 59 was also used with the 855 which has the same size tires as the 755. It would be interesting to see how the lower PTO hp 755 handles a 59.
JD 755, 70 Loader, 60 inch MMM, Landpride rear blade, Modern box blade, Wallace subsoiler
03-06-2013, 09:31 AM #16
My 955 has turf tires, no liquid. I built a 3pt weight made from cement to balance out the weight of the 59" blower. No pics currently, I can get a couple if your interested.
I did put the Deere remote spout control on this year, what little I've used the blower, its worked great.
Ed
03-06-2013, 03:33 PM #17
Dont mean to throw the thread off hope you dont mind Mechanos but us X55's have to stay close haha.
I have also been sitting and watching another add since December its a Gearbox, driveshaft, front bumper/hitch and hydraulics for a 755 as the gearbox s/n says. It is 20 hours away I am thinking of getting it shipped.
If i was to purchase this would i be better off as then i can get any 47" blower even another brand to make it work?
OR should i just hold off and wait for the 47.1988 John Deere 755
52 Loader
60" MMM
MFWD
Craftsman YS4500
03-06-2013, 05:46 PM #18
I like to play in the dirt....
Satoh Beaver w/Blackhawk loader & hoe.
JD855 w/stuff.
03-06-2013, 09:02 PM #19
A word to the wise for all you 55 series owners shopping for a 59: The sticker on the blower says "855/955 & 670/770", so I've noticed that most people assume that the whole setup fits all these tractors and they are advertised as such. In reality, the blower will fit the 855/955, 670/770, 790 & 3005, BUT the Quick-Tatch mounting brackets are different. There is one bracket that fits the 55 series, and a different mount that fits the 70 series, 790 & 3005. Make sure the one you're looking at has the right mounting bracket for YOUR tractor! The 55 series bracket is straight up & down on the sides and the 70 series, 790 & 3005 mounting bracket is flared out on sides.
55 series mount:
670/770, 790 & 3005 mount:
03-08-2013, 09:07 AM #20
Heres the weight I built, its appx. 15" x 15" x 22" wide, the tubes that go down in have rebar welded to them to keep the cement from falling off or breaking. Total weight is about 400lbs, never had a problem with lack of traction.
Ed
Similar Threads
Snow Can I Mount A Front Mount Snowblower Attachment With The BackHoe Still On My 2520
By coollx in forum John Deere Owning/OperatingReplies: 4Last Post: 04-22-2011, 02:47 PM -
Ballast Ballast box needed for BX2230 with front snowblower?
By Tablespoon in forum Kubota Owning/OperatingReplies: 9Last Post: 10-03-2009, 11:33 PM -
By tjmcd in forum Kubota Owning/OperatingReplies: 2Last Post: 12-27-2003, 06:12 PM -
By Deerlope in forum Kubota Owning/OperatingReplies: 6Last Post: 11-29-2003, 05:47 AM -
Snowblower NH front mount snowblower
By Rowski in forum AttachmentsReplies: 0Last Post: 01-07-2002, 07:26 PM
