Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. #21
    Veteran Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    Default Re: Ballast for a 59 front mount snowblower
    In case anyone is wondering (I was), on the 55 series tractors you can leave the Quick-Tatch bracket bolted to the tractor with the loader mounted. I needed to use the loader, but since I'm not 100% sure we won't get anymore snow this season, I didn't want to completely remove the Quick-Tatch bracket and Mid-to-bracket PTO shaft if I didn't have to. The design of the Quick-Tatch easily clears the parking stand of the 70A loader when mounting the loader on the tractor. It does hang down really low (below the front axle) so I wouldn't want to leave it there to do any serious loader work.
    Ballast for a 59 front mount snowblower-quicktatchfront-jpg Ballast for a 59 front mount snowblower-quicktatchleft-jpg Ballast for a 59 front mount snowblower-quicktatchright-jpg
  2. #22
    Platinum Member techwrtr2's Avatar
    Join Date
    Nov 2007
    Posts
    846
    Alabama PA
    Which one?
    Quote Originally Posted by Mechanos View Post
    I suspected as much... another reason I wouldn't mind getting a 59. I did know the brackets are specific to the 55 series, hence why I would only consider a complete package from a 55.
    I use my loader year-round and seldom even take it off during winter. Since my wallet won't allow me to buy an additional tractor, I need to get the most out of the one I have.
    I like to play in the dirt....
    Satoh Beaver w/Blackhawk loader & hoe.
    JD855 w/stuff.
  3. #23
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    Quote Originally Posted by techwrtr2 View Post
    I also seem to always have a use for the loader. Whether it's unloading or loading something heavy, moving something heavy, moving firewood around to the house to replenish the stack just outside the back door, etc. etc. So it was nice to be able to just drop the blower off the front and mount up the loader. If I need the blower, I can drop the loader and mount the blower in a just a few minutes. When spring rolls around and I know I won't need the blower anymore, I'll take the mounting bracket and PTO shaft off since I tend to move a lot of dirt/material in the spring/summer/fall and I don't need to be dragging the front bracket through the dirt.
    I've been quite impressed with the thought that's been put into the attachments for the x55 series tractors. The loader, sub-frame backhoe, front blower take just a few minutes to mount/dismount and brackets for one don't need to be removed in order to mount the other. I don't have the 380 front blade, but I understand the loader mounts need to be removed in order to install it. I also understand the belly mower can be a pain since you have to man-handle it into place or drag it out from under. I got around that by using a JD 272 RFM instead. The backhoe takes the longest since I do have to remove the 3pt draft/lifting/top links off.
    I would really like to have a belly mounted grader blade, but I've never seen one the 55's. That would probably have to be a custom made unit.
  4. #24
    Join Date
    Nov 2007
    Posts
    846
    Alabama PA
    Which one?
    I have the 72"mmm on my 855. It's not bad to remove if you are working on a concrete floor. Rolls very easily though you do need to lift the front of the tractor. If, like me, you don't have the option of always mounting/dismounting on a concrete floor, it gets old. I've been on the lookout for a 60" rear mount, not sure if my budget will allow it this year or not but I'm hopeful.
    JD855 w/stuff.
  5. #25
    Platinum Member JD755's Avatar
    Join Date
    Aug 2009
    Posts
    917
    Kansas
    John Deere 755 purchased new in 1993
    Just curious why you need to lift the tractor. Do you remove the left front deck wheel and turn the front tractor wheels full left before removal? I agree removal is not a problem as long as done on a concrete surface. Could be tough on the dirt/grass.
    JD 755, 70 Loader, 60 inch MMM, Landpride rear blade, Modern box blade, Wallace subsoiler
  6. #26
    Join Date
    Nov 2007
    Posts
    846
    Alabama PA
    Which one?
    If I took the wheel off, I would have to put it back on.
    As heavy as it is, I don't want it to have a corner minus a wheel. It's hard enough to push as it is.
    JD855 w/stuff.
  7. #27
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    Well, with Virgil bearing down on us, I pulled the 59 back out of storage and remounted it this afternoon. I just may get a chance to play with the new toy yet this season. I thought I had done my part to ensure that it would never snow here again by buying the 59.
  8. #28
    Join Date
    Nov 2007
    Posts
    846
    Alabama PA
    Which one?
    Did you get to play with the toy? I thought I heard St Louis got 15".
    JD855 w/stuff.
  9. #29
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    I'm on the other side of the state, but yes, I did get a chance to use it. We got about 8" or so, but again it was a very wet, heavy snow. One thing that I've noticed is that the skids really leave drag marks on the paved drive. The little model 49 on my 322 barely leaves a mark, but then again, I'm sure the model 59 is a lot heavier. It got me to thinking about some kind of high density plastic wear pads for the bottoms of the skids, but I don't know what material would hold up the best.
  10. #30
    Bronze Member cobracnvt's Avatar
    Join Date
    May 2012
    Posts
    52
    Massachusetts
    John Deere 3320 and 345
    Default
    Mechanos, Do you have any pictures of the marks on the driveway? I have been thinking about getting a larger 3 PT or 59" front mount snow blower for my 3320, but I don't want to mark up my asphalt driveway with it.
    I have a 42" on my 345, and it doesn't mark up the driveway at all.
Similar Threads
  1. Snow Can I Mount A Front Mount Snowblower Attachment With The BackHoe Still On My 2520
    By coollx in forum John Deere Owning/Operating
    Last Post: 04-22-2011, 02:47 PM
  2. Ballast Ballast box needed for BX2230 with front snowblower?
    By Tablespoon in forum Kubota Owning/Operating
    Last Post: 10-03-2009, 11:33 PM
  3. Front mount snowblower
    By tjmcd in forum Kubota Owning/Operating
    Last Post: 12-27-2003, 06:12 PM
  4. front mount snowblower
    By Deerlope in forum Kubota Owning/Operating
    Last Post: 11-29-2003, 05:47 AM
  5. Snowblower NH front mount snowblower
    By Rowski in forum Attachments
    Last Post: 01-07-2002, 07:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
