Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Nov 2012
    Posts
    2
    Prior Lake, MN
    John Deere 650
    Default JD 650 Transmission Part - Help?
    Earlier this week I was scraping snow off the drive with my JD650 and back blade. On the trip back to the garage, a bad noise came from the tranny case followed by some binding and a couple clunks I lifted the blade and tried to put it in 1st but no go. 2,3,4 H&L worked, so I put it in 2 and crawled into the garage at low RPMs.
    Last night I broke her apart between the tranny case and clutch housing, pulled out the gear set to see what is going on. The fork for the 1-5/R gear had snapped off.
    Its PN CH14900 but I can't find one in the JD Dealer netwwork or any of the placese I've look on the web today. If you have one / or know where I can get one, please drop me a note.
    mitch
    JD 650 Transmission Part - Help?-20130306_210609.jpgJD 650 Transmission Part - Help?-20130306_210621.jpg
  2. #2
    Veteran Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    2,113
    South West MI
    John Deere 2030, John Deere 6415
    Default Re: JD 650 Transmission Part - Help?
    Try All State AG Parts 877-530-2010 Good luck!
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  3. #3
    New Member
    Join Date
    Aug 2012
    Posts
    2
    Jonesboro, Georgia
    John Deere 750
    Try Hoye Tractor in Texas. They are a Yanmar dealer but the 650 was made by Yanmar. If you give them the JD part number they may be able to cross reference it. Also try Weavers compact tractor Weaver's Compact Tractor Parts & Compact Tractor Salvage
  4. #4
    New Member
    Join Date
    Nov 2012
    Posts
    2
    Prior Lake, MN
    John Deere 650
    Well, I've "bought" one that never showed up. Place was nice about it after their supplier didn't ship and is sending a refund. So, today I got in touch with a machine shop and dropped off the two broken pieces. They feel pretty good about making me a new one, but it will be a day or two till I get and estimate on the cost. Anybody else want one made as I'm sure after setup, making another 1 or 2 is not much more.
Similar Threads
  1. john deere 650 need shift fork part # CH14900
    By wthompson in forum John Deere Owning/Operating
    Last Post: 04-23-2012, 07:40 PM
  2. cub 5234d transmission part lookup
    By Cub5k in forum Cub Cadet Yanmar & CUTs
    Last Post: 10-30-2010, 05:57 PM
  3. Oil & Fuel 2 part gas to 1 part oil = unhappy 425 owner
    By PTOuser in forum Power Trac
    Last Post: 09-09-2009, 07:54 PM
  4. JD 650 transmission woes?????
    By kmosabe in forum John Deere Owning/Operating
    Last Post: 05-03-2007, 04:46 PM
  5. Backhoe Yanmar YBH-650 backhoe is a Woods 650!
    By MDL in forum Yanmar
    Last Post: 06-06-2002, 11:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
