Results 1 to 4 of 4
  1. #1
    Member
    Join Date
    Feb 2011
    Posts
    43
    Middletown CT
    John Deere 2720
    Default 200CX Parking Stand Repair
    Last Fall when removing my 200CX the Parking Stand bent. After filing a complaint with JD and getting no satisfaction (JD rep. said the stand is not a big problem only 400 stands sold in 5 years) I decided to fix the stand myself and reinforce it. JD could warranty that a new stand would not ever bend.
    Here is what I did.
    Upon first inspection you can see the slot where the tube back plate goes into the mount brackets. This area was not welded at all.
    Since I could see the mounting brackets were bent also I decided to cut them off at the welds and straighten those pieces first. The welds were easily cut since the factory welds did not go completely thru the steel. This is a bad welding practice in my book.
    I took a pic of the bracket after I cut it off. You can easily rust forming where the tube met the bracket and no paint got into the small open crack.
    Next I heated up the tubes and straighten them.
    Then I welded a piece of シ thick by 1-1/2 bar stock to the underside forming a gusset plate.
    It will take a lot to bend that.
    Then I installed the brackets on 200CX frame and positioned the stand where it was originally using pics of the tractor when it was new. (Good reason to take good pics.)
    With the tractor covered I spot welded the tube to the brackets, then removed the stand and finished the welds.
    I have attached a pic of the finished stand in primer.
    When primer dried I installed the completed unit and tested it to make sure the gusset bar did not hit or interfere with anything. I found plenty of room I could have even installed a bigger bar.
    Final pic is the stand now repainted in JD green and ready to be installed.
    FYI: The stand can be installed and removed with the 200CX on the tractor. A little tricky but it can be done.
    Paul
    In CT.
    Attached Thumbnails Attached Thumbnails 200CX Parking Stand Repair-1_bent-stand-1-jpg   200CX Parking Stand Repair-2_not-welded-thru-jpg   200CX Parking Stand Repair-3-rust-not-welded-jpg   200CX Parking Stand Repair-4_straight-tubes-jpg   200CX Parking Stand Repair-5_remount1-jpg
    200CX Parking Stand Repair-6_remount2-jpg   200CX Parking Stand Repair-7_org-postion-jpg   200CX Parking Stand Repair-8_fixed-stand-primer-jpg   200CX Parking Stand Repair-9_the-test-jpg   200CX Parking Stand Repair-10_jd-green-jpg
  2. #2
    Join Date
    Mar 2007
    Posts
    69
    Default Re: 200CX Parking Stand Repair
    It is funny they keep up that story about the stands....the two that I have owned in the last three years, and the dealer told me they are all a little bent after a few on and offs...
  3. #3
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,913
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Nice job Paul!
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  4. #4
    Member
    Join Date
    Feb 2011
    Posts
    43
    Middletown CT
    John Deere 2720
    Thank you for the compliments. I really did not want to pay $300+ for a new stand whichmight bend in the future.
    I donot think the 1/4" thick bar will bend and it really does not look to bad since its under the tube.
    I just look at an add for a JD 2305 for sale and he stand is bent worse then mine was. I would bet plenty of owners are limping along with bent parking stands since you really do not use them much.
Similar Threads
  1. 200cx loader parking stand
    By Lobo56 in forum John Deere Owning/Operating
    Last Post: 02-05-2013, 09:58 PM
  2. Loader Parking Stand For The H120 Loader.
    By chevy in forum John Deere Owning/Operating
    Last Post: 01-12-2013, 10:39 PM
  3. 3032e Parking Stand Kit
    By Wolfman in forum John Deere Buying/Pricing
    Last Post: 03-15-2012, 02:38 PM
  4. Tires Tires rubbing parking stand on 2520
    By Boltman in forum John Deere Owning/Operating
    Last Post: 03-26-2011, 11:35 AM
  5. Bent 200cx Parking Stand
    By etcallhome in forum John Deere Owning/Operating
    Last Post: 11-30-2008, 03:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
