Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 41
  1. #11
    Veteran Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    Default Re: need parts gurus fast help JD blower fitment
    Looks good. I question that it came off of a 3320, as the lifting mechanisms in your pictures show the 855/955, 670/770, 790, 3005 style mount.
    V8, I saw the attaching bracket you'll need listed on ebay the other day. It was just the bracket minus the short little PTO stub shaft.
  2. #12
    Silver Member v8only's Avatar
    Join Date
    May 2012
    Posts
    214
    Mb
    1988 John Deere 755
    Yea after seeing your photo i also question that it came from a 3320. Before i went to go look at the unit I knew what the brackets should look like to fit the 55 series so when i saw the lifting arms on this guy i scooped it up.
    Ill look for the bracket, what should i search X55 front bracket?
    Thanks
    1988 John Deere 755
    52 Loader
    JD 59 Front mount snowblower
    60" MMM
    MFWD
    48" JD Model 40 tiller
    Craftsman YS4500
    22 Hp Briggs & Stratton
  3. #13
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    Quote Originally Posted by v8only View Post
    Thanks
    Search it by part number "AM106975" Also, I noticed there is a mid-to-bracket PTO shaft listed as well. Search "755"
    One other thing I'm curious about... is the width between the frame rails on the 755 the same as the 955? The width of the bracket for the 955 is 11.5"
    need parts gurus fast help JD blower fitment-2013-03-14_18-33-39_949-a
  4. #14
    Join Date
    May 2012
    Posts
    214
    Mb
    1988 John Deere 755
    Mechanos,
    can you measure your hydraulic lift cylinder for me.
    Bore dia:
    Stroke Length:
    Retracted length: pin to pin
    Pin hold diameter:
    Id like to get a generic lift cylinder instead of the JD one as they want $300.00 for it
    1988 John Deere 755
    52 Loader
    60" MMM
    MFWD
    Craftsman YS4500
  5. #15
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    Mechanos,
    Bore dia:
    Stroke Length:
    Pin hold diameter:
    Does this help?
    Specification
    Weight 6.64 LBS 3.01 Kg
    Bore Diameter 2.500 IN
    Rod Diameter 1.000 IN
    Stroke 4.250 IN
    Closed Length 9.842 IN
    End Type-Rod & Cap 0101
    Rod End Size 0.516 IN
    Cap End Size 0.516 IN
    Working Pressure 1,999.999 PSI
    need parts gurus fast help JD blower fitment-24960103-jpg
  6. #16
    Platinum Member JD755's Avatar
    Join Date
    Aug 2009
    Posts
    917
    Kansas
    John Deere 755 purchased new in 1993
    Quote Originally Posted by Mechanos View Post
    Inside bracket width on 755 is also 11.5 inches. Outside frame dimension is 14 inches.
    Attached Thumbnails Attached Thumbnails need parts gurus fast help JD blower fitment-frame-dim-jpg
    JD 755, 70 Loader, 60 inch MMM, Landpride rear blade, Modern box blade, Wallace subsoiler
  7. #17
    Join Date
    May 2012
    Posts
    214
    Mb
    1988 John Deere 755
    1988 John Deere 755
    52 Loader
    60" MMM
    MFWD
    Craftsman YS4500
  8. #18
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    You will also need the Mid-to-bracket PTO shaft (AM102812). The bracket you linked to is actually the part number needed for the 55's, the P/N I listed above is the wrong one... it's for the 670/770. The ad in your link is a good value as it is 3 of the parts you need in one... if you were to buy that from Deere, you'd have to buy the bracket, the PTO stubby shaft thingy, and the lift cylinder as 3 separate parts; each of which would cost more than the listed price of that ad.
  9. #19
    Join Date
    May 2012
    Posts
    214
    Mb
    1988 John Deere 755
    I am hoping i can use my MMM shaft or my tiller shaft.
    1988 John Deere 755
    52 Loader
    60" MMM
    MFWD
    Craftsman YS4500
  10. #20
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    Hope in one hand and poop in the other.... see which one fills up first.
    MMM shaft won't work... it's way too short. The shaft needed to reach the front of the tractor is about twice the length of your MMM shaft. Your tiller shaft is, no doubt, for a rear mounted tiller and therefore would fit 1 3/8" - 6 spline PTO shaft. The mid PTO uses 1" - 15 spline, so the tiller shaft won't work either.
Similar Threads
  1. Snow Equipment Buying/Pricing MK Martin snow blower parts
    By chuckcar70 in forum Snow Removal
    Last Post: 12-19-2011, 05:53 PM
  2. Looking for MTD blower parts.
    By SARG in forum MTD
    Last Post: 04-12-2011, 08:59 AM
  3. Snow B2550 Blower parts???
    By DoktorC in forum Kubota Owning/Operating
    Last Post: 04-07-2010, 10:37 PM
  4. wearing out parts too fast
    By jiffymx in forum Parts/Repairs
    Last Post: 12-20-2006, 08:07 PM
  5. DX40 Loader 'Fast Dump' not fast at all
    By KenVT in forum New Holland Owning/Operating
    Last Post: 05-07-2006, 08:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
