Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Join Date
    Mar 2013
    Posts
    73
    CT
    JD X728
    Default Re: JD 47" snowblower gearbox question
    Henri:
    Is your blower a model 47?
  2. #12
    Platinum Member Henri88's Avatar
    Join Date
    Nov 2009
    Posts
    759
    Northern N.B.
    2008 JD 2305, 800hr
    I took a run and measure the free play in my auger. It's about 3/4" taken from the highest point of the auger. Hope this help a little. Took a few pictures of mine but if like you said 5 year old it would be the same.
    JD 47" snowblower gearbox question-img_0290-jpg JD 47" snowblower gearbox question-img_0292-jpg JD 47" snowblower gearbox question-img_0291-jpg
    Henri
    How could you be told I was french?
    Rotary cutter 4' Howse , mid mount mower 54'' , f.e. loader 200CX , tiller RT1150 Frontier , cultivator PC1001 Frontier , middle buster PM1001 Frontier , JD 47'' front snowblower , pallet forks , 4' boxblade Agriease , grass-sweeper , quick hitch Speeco , trailer hitch , cab Jodale-Perry , trailer 16' galvanized Easy-Hauler ,
  3. #13
    Join Date
    Mar 2013
    Posts
    73
    CT
    JD X728
    Quote Originally Posted by Henri88 View Post
    Yes that looks just like my machine but mine had more like an inch and a half of play so thank you that does help. I cleaned up the parts and took a close look at things and the slot in the shaft is badly beat up while the gearbox looks good so I'm a happy camper.
    Now I am looking for a good way to repair the key slot in the shaft. I am considering using some silver solder in the slot and then filing it to fit. It will be tough because the shaft needs to slide smoothly in the gearbox when assembled. At worse I will need to get a new shaft which is a site cheaper than a new gearbox.
Similar Threads
  1. Model 47 Snowblower gearbox question
    By mikefamig in forum Attachments
    Last Post: 03-15-2013, 01:19 PM
  2. meteor snowblower gearbox question
    By sierradmax in forum Attachments
    Last Post: 12-04-2012, 02:13 PM
  3. 47" Snowblower Question
    By psdx in forum John Deere Lawn & Garden
    Last Post: 12-28-2011, 09:48 PM
  4. 47" Snowblower Question #2
    By Wyobuckaroo in forum John Deere Owning/Operating
    Last Post: 12-05-2011, 06:03 PM
  5. Another 47" Snowblower Question/Problem!
    By brittgers in forum John Deere Owning/Operating
    Last Post: 02-27-2007, 11:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
