Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    Join Date
    May 2008
    Posts
    847
    Eastern Ia
    JD 4310 eHydro, JD 322
    Default Re: Seal, which way should it go
    I cannot tell from the pictures, but have always went on the addage lip to the pressure, or what you want to contain.
  2. #12
    Elite Member Chilly807's Avatar
    Join Date
    Sep 2009
    Posts
    2,778
    Nova Scotia
    Kubota L3400DT
    Is there a garter spring in the seal? If so, that is definitely on the oil side. A double lip seal is designed so the outer lip keeps contaminants such as sawdust or dirt from getting to the oil sealing lip and damaging it. Generally, any lettering will be on the dry side of the seal as the guys have said.
    Sean
  3. #13
    Elite Member whistlepig's Avatar
    Join Date
    Jan 2009
    Posts
    3,564
    Preble County, Ohio
    Kubota B7800 with FEL
    Quote Originally Posted by mfreund View Post
    If a grease bearing is over greased the only place for it to relieve is through the lip in the seal. If lip out the grease can seep through. If lip in it the pressure of the grease will blow out the seal.
    ........Shoot this thang! Have mercy this thang is killin' me. Just shoot up here amongst us. One of us has got to have some relief..............
    jerry clowers-a coon huntin story.
  4. #14
    Platinum Member Henri88's Avatar
    Join Date
    Nov 2009
    Posts
    583
    Northern N.B.
    2008 2305 jd
    Ok, so I took a run to my garage and had a better look at the seal. First, yes there is a spring inside and it is on the inside lip in other word if you are looking at the seal with the # facing you, it would be the second lip inside. That lip is also different than the other one. It is made more like a V shape. The other lip closest to you or I should say closest to the face of the seal with the # is more like a wiper lip and is shape going outside. I took some more pics. So if logic stands, the lip with the spring, shape like a V should be the oil seal and the other lip should be the one stopping the contaminant from going in which mean the seal is wrongly install. Your thoughts please.
    Seal, which way should it go-img_0331.jpg Seal, which way should it go-img_0335.jpg Seal, which way should it go-img_0330.jpg
    How could you be told I was french?
    4' Howse rotary cutter, mid mount lawnmower, f.e.loader, pallet forks, tiller, cultivator, middle buster, snowblower, grass-sweeper, quick hitch, trailer hitch, jodale-perry cab
  5. #15
    Join Date
    Jan 2009
    Posts
    3,564
    Preble County, Ohio
    Spring matters not. Lip in for oil. Lip out for grease.
  6. #16
    Join Date
    Nov 2009
    Posts
    583
    Northern N.B.
    2008 2305 jd
    Quote Originally Posted by whistlepig View Post
    I don't get it. There is no grease and both lip are different. You may be right but I still don't no by your quote which lip is the oil seal.
  7. #17
    Join Date
    Jan 2009
    Posts
    3,564
    Preble County, Ohio
    We replace bearings on chilled cast iron calender rollers for paper mills and steel mills. These calender rollers weigh 35 tons+. The bearings for these calender rollers are most time grease bearings but sometimes oil bearings. A single spherical bearing for one these rollers costs from $3,000-$4,000. It's lip in for oil and lip out for grease. Regardless of which side the numbers on the seal are.
  8. #18
    Join Date
    Apr 2011
    Posts
    179
    Marysville, OH
    JD 4300
    Default
    The side where you can see the spring defiantly goes towards the oil.
  9. #19
    New Member
    Join Date
    Mar 2013
    Posts
    4
    UK
    Lanz 710
    You are correct in what you are saying, this is indeed a double lip type seal, the open side of the seal should face the oil or grease. the other outer lip is to prevent contamination from entering the seal and bearing area.
    Before installing the seal I would check the bearing and shaft for any excessive wear that would make the new seal weep oil. Another thing to check here is that the vent/ breather on the housing is clear and that there is no chance that pressure could build up within the housing.
    Hope this is of some help
  10. #20
    Veteran Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    1,551
    Cumberland Plateau, TN
    Bobcat CT225
    Quote Originally Posted by BRBurns View Post
    Spring side with a lip is fluid retention.
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
Similar Threads
  1. Jinma 254 Front 4x4 drive gear re-seal / oil seal direction?
    By tigers2007 in forum Chinese Tractors
    Last Post: 05-06-2011, 12:14 AM
  2. 1500d front seal won't seal?
    By JAY34 in forum Yanmar
    Last Post: 09-09-2004, 03:50 PM
  3. Seal
    By jd0716 in forum Owning/Operating
    Last Post: 06-04-2004, 11:50 PM
  4. PTO Seal
    By king1010 in forum Massey Ferguson Owning/Operating
    Last Post: 06-04-2004, 07:53 PM
  5. PTO SEAL
    By king1010 in forum Owning/Operating
    Last Post: 05-28-2004, 04:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
