Results 21 to 26 of 26
03-17-2013, 07:14 AM #21Super Member
- Join Date
- Sep 2000
- Posts
- 6,266
- Location
- Eastern NY
- Tractor
- Case 885, JD 730D, Oliver 660 Ford 4000
Re: Seal, which way should it go
The garter spring is NEVER installed towards the elements, period. A 'grease' seal as you describe with the lip facing outwards so as to relieve pressure will not have a garter spring.
This is an oil seal application and your comments about grease seals, while relevant in the big picture, are confusing the OP and the immediate example of an OIL seal.If you can read this, thank a teacher.
If you are reading this in English, thank a veteran.
03-17-2013, 07:32 AM #22New Member
- Join Date
- Mar 2013
- Posts
- 4
- Location
- UK
- Tractor
- Lanz 710
As I said the open side of this double lip seal (Garter spring side) should always face the oil or grease, and the other side of the seal being used for contamination prevention.
This seal is in no way designed to relieve any pressure that might build up within the housing, that is why a breather would be fitted.
03-17-2013, 07:43 AM #23
03-17-2013, 08:21 AM #24
Thank you guys! Now this really help and it makes more sense than the way it was install. Donald, yes that is the first thing I check. The bearing is nice and tight and the output shaft is strait. I also remove the breather, had it soak in a rust remover, made sure the little "ball spring check valve" inside worked good and reinstall. Now I can proceed with the installation of the seal and work on making a chain guard. Henri
How could you be told I was french?
4' Howse rotary cutter, mid mount lawnmower, f.e.loader, pallet forks, tiller, cultivator, middle buster, snowblower, grass-sweeper, quick hitch, trailer hitch, jodale-perry cab
03-18-2013, 09:15 PM #25
03-18-2013, 09:32 PM #26
I think you'll have better luck with the seal not leaking this time.
Sean
Similar Threads
Jinma 254 Front 4x4 drive gear re-seal / oil seal direction?
By tigers2007 in forum Chinese TractorsReplies: 3Last Post: 05-06-2011, 12:14 AM -
1500d front seal won't seal?
By JAY34 in forum YanmarReplies: 10Last Post: 09-09-2004, 03:50 PM -
Seal
By jd0716 in forum Owning/OperatingReplies: 0Last Post: 06-04-2004, 11:50 PM -
PTO Seal
By king1010 in forum Massey Ferguson Owning/OperatingReplies: 1Last Post: 06-04-2004, 07:53 PM -
PTO SEAL
By king1010 in forum Owning/OperatingReplies: 2Last Post: 05-28-2004, 04:36 AM
