Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,080
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: Power Beyond to run a log splitter on JD 1640
    mickeyw
    The primitive way to check the log splitter valve to determine if it's OC or CC is disconnect return hose from sump then aim return hose in hyd reservoir neck,with control lever in neutral crank LS engine and if oil flows out return hose it's a OC valve , no oil flows out return hose it's a CC valve. I'm betting it's an OC valve
  2. #12
    Member
    Join Date
    Dec 2012
    Posts
    46
    Surrey, UK
    1981 JD1640, 1970 Ford 3000
    Thanks for that link Kenny. I've registered on there, will have to find some time to peruse.
    My valve came from a UK company flowfitonline.com. They sell Bucher valves and pumps, but they also have their own branded range, which is what I have. I shall email them and ask for confirmation of the valve type and whether it can be changed easily.
  3. #13
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    If your tractor is a closed center hyd system, then this is the valve you should use.
    Surplus Center - 1 SPOOL 30 GPM CLOSED CENTER LOG SPLITTER VALVE
    You plumb it in parrallel with the other valves.
    Same pressure line will feed each valve in parrallel.
    If you put a hyd gage in a tee at the IN port of the CC log splitter valve, you will have some pressure, maybe standby pressure or full pressure with tractor running.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  4. #14
    Member
    Join Date
    Dec 2012
    Posts
    46
    Surrey, UK
    My alternative may be to hook this up to our Ford 3000, as that has hydraulics for the FEL, and would be easy to tap into. However I have read that the Ford hydraulic pump doesn't run at very high pressure. Might be worth a try anyway.
  5. #15
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    You should have good pressure for the log splitter.
    1970 Ford 3000
    Hydraulics:
    Type: open center
    Pressure: 2500 psi [172.4 bar]
    Pump flow: 5 gpm [18.9 lpm]
    Steering flow: 4.25 gpm [16.1 lpm]
    Steering press.: 600 psi [41.4 bar]
    J.J.
    Git er done.
  6. #16
    Member
    Join Date
    Dec 2012
    Posts
    46
    Surrey, UK
    Well, this afternoon I made the first run with my splitter connected to the JD. This was principally to check it functioned OK mechanically.
    To avoid adding complication I chose to connect the cylinder directly to the tractor's on board spool. Results were positive
    Observations :
    The tractor control lever will stay in either forward or back position without the need to be held there.
    When the cylinder reaches full travel the lever stays put, but the pressure clearly drops off. What does this tell us about the hydraulic valve type?
    This behaviour makes me wonder whether an external valve could in fact be used without any changes or additions to the circuit.
  7. #17
    Member
    Join Date
    Dec 2012
    Posts
    46
    Surrey, UK
    Quote Originally Posted by J_J View Post
    1970 Ford 3000
    Hydraulics:
    Type: open center
    Thanks for these figures JJ. Interesting to see steering mentioned, we have the poverty spec model, lol. With a FEL on the Ford it's good for building the upper body
  8. #18
    Join Date
    Jan 2007
    Posts
    7,080
    Coyote Flats,Tx
    Quote Originally Posted by mickeyw View Post
    Observations :
    The remote lever on the 1640 should kick back into neutral after cylinder reaches its full travel either direction. I looked in parts catalog and I think your tractor will have spool valves.
    Attached Thumbnails Attached Thumbnails Power Beyond to run a log splitter on JD 1640-l117982________un20oct95-gif
Similar Threads
  1. HELP can I adapt a 5hp log splitter to run off tractor?
    By joulian in forum Owning/Operating
    Last Post: 04-26-2012, 08:56 AM
  2. Hydraulic run Log Splitter Question
    By Ari in forum Hydraulics
    Last Post: 02-09-2012, 04:36 PM
  3. Buying Advice Will X748 Run a 3-pt hitch log splitter
    By OneMarineE5 in forum John Deere Buying/Pricing
    Last Post: 07-17-2011, 10:28 PM
  4. T5C run a log splitter?
    By cstamm81 in forum Terramite
    Last Post: 11-18-2010, 10:25 AM
  5. Whats the chance a 4100 will run this log splitter?
    By acs55812 in forum John Deere Owning/Operating
    Last Post: 08-24-2010, 08:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
