Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Gold Member
    Join Date
    Jun 2008
    Posts
    278
    Kentucky
    John Deere 3320 - gator cx
    Default 3RD function loader lines
    I thinking of adding the 3 function hydraulics to my 300cx loader. Where do the lines hook to to get hydraulic fluid? I don't have the diverter valve hookup, but I have the third scv in the rear. Do I run the lines to that? The parts break down from JD don't show where to hook to.
  2. #2
    Join Date
    Jul 2012
    Posts
    1,120
    Southeast Minnesota
    JD 4720, JD X748SE, JD 997, Farmall "B"
    Default Re: 3RD function loader lines
    Quote Originally Posted by jd670 View Post
    Yes, It goes to the rear. What you get is 2 hoses that get you to the connection point of the other 4 loader hose quick connects. You get another bracket that will accomodate 6 quick connects instead of 4.
  3. #3
    Gold Member
    Join Date
    Jun 2008
    Posts
    278
    Kentucky
    Ok. Then its up to me to run hoses to the rear scv?
  4. #4
    Join Date
    Jul 2012
    Posts
    1,120
    Southeast Minnesota
    Yes. I bought mine when I bought my tractor, so the dealer did it, but it was just zip tied to the hydraulic hard lines that go back there. Running the lines on the loader itself will be more of a pain.
  5. #5
    Super Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
    Quote Originally Posted by arlen4720 View Post
    The loader lines and the 2 SCV connectors (for grapple hoses, etc.) are hard-lines and part of a kit with attachment clips and bolt's, etc.
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
  6. #6
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,912
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Yes, the lines go to the rear couplers for the 3rd SCV.
    Here is what you get in the JD kit:
    3RD function loader lines-300cx-gif
    HYDRAULIC HOSES AND OIL TUBES - THIRD FUNCTION (300CX)
    Cart key PART NO. PART NAME QTY SERIAL NO. 300 300X 300CX REMARKS
    1 M42702 Snap Ring 2 X
    2 AW32609 Line 2 X
    3 W45635 Plug 1 X (A) (C)
    ...... Plug 1 X (B) (C) (ORD AW28043)
    4 AW30147 Hydraulic Hose 2 X 3/4" X 1800 mm (70-3/4") X 17.4752"
    5 W45608 Cap 1 X (A) (C)
    ...... Cap 1 X (B) (C) (ORD AW28043)
    6 AR94522 Hydr.Quick Coupler Plug 2 X
    7 W45609 Cap 1 X (A) (D)
    W42991 Cap 1 X (A) (E)
    ...... Cap 1 X (B) (E) (ORD AW28043)
    8 AW30239 Hose 2 X 3/4" X 2300MM (90-1/2") X 3/4"
    9 W42411 Cap 1 X (A) (F)
    10 R105388 Tie Band 4 X
    11 W45634 Plug 1 X (A) (D)
    ...... Plug 1 X (B) (E) (ORD AW28043)
    12A W45797 Bracket 1 X (SUB W52215)
    12B W53059 Bracket 1 X (SUB FOR W52215)
    13 LVA12997 Hyd. Quick-Connect Coupler 2 X (A) 3/8", (SUB FOR AM105466, THIS APPL)
    LVA13231 Hyd. Quick-Connect Coupler 2 X (B) 1/2"
    14 AW32982 Oil Line 1 X
    15 AW32983 Oil Line 1 X
    16 W44542 Block Clamp 1 X
    17 W52153 Screw 2 X (SUB FOR 19M8040, THIS APPL)
    18 M70728 Cap 1 X (F)
    W53377 Cap 1 X (E) 1/4"
    19 X4010-T6 Hydr.Quick Coupler Plug 1 X (SUB FOR AW32184)
    20 32246 O-Ring 1 X
    21 AM102487 Hyd. Quick-Connect Coupler 1 X
    22 M85099 Plug 1 X (A) (F)
    W53387 Plug 1 X (C) 1/4"
    23 W50244 Hose Clamp 6 X
    24 19M7286 Cap Screw 2 X M6 X 25
    25 14M7272 Nut 2 X M6
    26 R26448 O-Ring 2 X
    27 T77613 O-Ring 4 X
    28 AM105467 Hydr.Quick Coupler Plug 2 X (A)
    AR94522 Hydr.Quick Coupler Plug 2 X (B)
    29 R26375 O-Ring 6 X
    30 19M7286 Cap Screw 2 X M6 X 25
    31 14M7272 Nut 2 X M6
    32 ...... Cap 1 X (B) (E) (ORD AW28043)
    .. AW28043 Plug 1 X (G) (I) 1/2"
    .. AW34729 Quick Coupler Kit 1 X (H) (J) 1/2"
    (A) FOR MACHINES WITH 3/8" COUPLERS PRIOR TO 1NOV. 06(B) FOR MACHINES WITH 1/2" COUPLERS
    (C) Orange(D) Blue(E) Green
    (F) Black(G) Dust cap and plug(H) Coupler conversion
    (I) Contains six colored caps and plugs(J) Contains AR94522 and 4 color dust caps
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  7. #7
    Gold Member
    Join Date
    Jun 2008
    Posts
    278
    Kentucky
    I see now. The lines that go under are roughly 5 feet long. They should reach to the back scv. Thanks guys for the help. I'll get the kit ordered.
  8. #8
    Gold Member
    Join Date
    Jun 2008
    Posts
    278
    Kentucky
    I found a complete kit on ebay for a 400cx loader for $100.00. I crossed referenced the part numbers for a 300cx kit and the only thing I found to be different was the hose bracket and a couple of colored hose plugs. The kit was brand new. I went ahead and bought it. Should be here Monday.
  9. #9
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    Whoa...! That's a real score! Hope it's all there.
    AKfish
  10. #10
    Gold Member
    Join Date
    Jun 2008
    Posts
    278
    Kentucky
    Me too. From the pics he had posted it looked to be.
Similar Threads
  1. Bobcat CT335 loader 3rd function hard lines
    By bubbacuse77 in forum Hydraulics
    Last Post: 10-19-2012, 10:11 PM
  2. 3rd function loader control switch help
    By B3300SU in forum Hydraulics
    Last Post: 02-21-2011, 11:52 AM
  3. Deere 430 Loader 3rd Function
    By jgbanshee in forum John Deere Lawn & Garden
    Last Post: 11-08-2009, 12:01 PM
  4. 3rd Function FEL remote loader switch
    By shaley in forum Build-It Yourself
    Last Post: 02-01-2007, 12:23 PM
  5. 3rd function loader hydraulics? connector issues
    By Sparkeee24 in forum Owning/Operating
    Last Post: 06-05-2005, 10:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
