Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Apr 2013
    Posts
    2
    Shelbyville, KY
    JD 2305, JD 6400
    Default JD 6400 Low Transmission/Hydraulic pressure
    Recently purchased a 1197 JD 6400 with quad shift transmission and front end loader. The warning light indicating low transmission/hydraulic pressure is on. Fluid levels are fine. I'm guessing either bad sensor, clogged screen restricting flow, or worst case...bad pump. Looking for help on where to start. I need to get the manuals still so I'm a little in the dark right now. I'm really hoping it is something simple. 3700 hours on the tractor. Any help would be greatly appreciated.
    Thanks,
    Ben
  2. #2
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,233
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: JD 6400 Low Transmission/Hydraulic pressure
    I'd suggest to change hy filter.
  3. #3
    Join Date
    Dec 2001
    Posts
    1,356
    Maryland
    TxJim, assuming the filter restriction switch and light are working, the filter is probably OK. The Trans pressure sensors are noted for failing occasionally, especially the original style. It is a good idea to replace the filter first to be sure, but I am betting on a bad sensor. It would be #12 in the diagram. The diagram pictures the new style sensor. The original one looks different. The hex portion for the wrench is the largest part. It will take a 30 mm wrench or socket to remove. The new one takes a 9/16" wrench. It is on the front valve housing of the transmission. If you have mfwd, it is a little more challenging to change because of the driveshaft in the way. JD 6400 Low Transmission/Hydraulic pressure-py015011_______un23feb09-gif
  4. #4
    Join Date
    Jan 2007
    Posts
    7,233
    Coyote Flats,Tx
    jd110
    You're probably correct but I was taught to do the easiest things first and changing the filter is easy compare to other things.
  5. #5
    New Member
    Join Date
    Apr 2013
    Posts
    2
    Shelbyville, KY
    JD 2305, JD 6400
    Thanks for the replies. It was supposedly just serviced with new filters/fluid, but that is a pretty simple thing to change just in case. I'll track down the sensor and try that next.
Similar Threads
  1. ivt transmission low oil pressure
    By bblawn in forum Parts/Repairs
    Last Post: 02-03-2013, 07:23 PM
  2. JX95 Low Transmission Pressure light
    By Pkneibert in forum Case-IH
    Last Post: 10-28-2012, 03:48 PM
  3. 6220 STOP Low transmission pressure
    By khufstedler in forum John Deere Owning/Operating
    Last Post: 07-05-2011, 10:03 PM
  4. JD 6400 Hydraulic Pressure
    By russhog in forum Hydraulics
    Last Post: 05-09-2010, 10:00 PM
  5. 6400 low hydraulic pressure
    Last Post: 04-18-2010, 04:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
