Results 1 to 7 of 7
  1. #1
    Join Date
    Apr 2010
    Posts
    59
    Default 3032e how much disc can it handle?
    Wondering what you all think. I'm going to load the tires here shortly. I have a small king kutter disc but I'm looking for something heavier duty. Looking at both 3 point and pull.
    What do you think would be a good disc for this (small) tractor?
  2. #2
    Join Date
    Apr 2013
    Posts
    151
    monroe county
    Default Re: 3032e how much disc can it handle?
    What kind of soil are you in ?
    [my 3032e comes Saturday]
    -forest creature (yes, the same one - can't get into my old account name)
  3. #3
    Elite Member RollingsFarms's Avatar
    Join Date
    Mar 2007
    Posts
    2,537
    South Carolina
    Few John Deere's and one Ford 3600 diesel.
    Default
    I would guess 5'. Certainly no more then that I wouldn't think and 4' might not be wide enough.
    Great grandpa drove blue, grandpa drove green, dad drove red and I drive blue and green
  4. #4
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,052
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    I think that a pull type disk small enough for a 2000# 25 pto hp isn't built unless it was something similar to a JD KBA disk which are known for their limited penetration.. I think a 5 ft 3 pt if put in the ground will load it.
    Attached Thumbnails Attached Thumbnails 3032e how much disc can it handle?-capture-jpg
  5. #5
    Advertiser EverythingAttachments's Avatar
    Join Date
    Mar 2009
    Posts
    3,477
    Newton NC
    Which One do you want to know about?
    Check out our Xtreme Duty Box Frame Disc harrows. You should be able to handle the 16x16 or 16x18 just fine. They are quick hitch and iMatch compatible and the hitch is designed for Cat 1 compact tractors.
    Ted Corriher
    www.EverythingAttachments.com
    1-866-581-5818
    A family-owned American Company that also sells quality Made in USA Implements every chance we get! We pride ourselves on giving good product information and putting the needs of our customers above our own!
  6. #6
    Join Date
    Apr 2010
    Posts
    59
    Default
    I have clay.
    I currently have a 5' disc and its no chore at all to pull even with with weight added.
    Like those eta discs. Will look into them.
    By the way, When is eta going to make something that will spread ag lime?
  7. #7
    Elite Member foggy1111's Avatar
    Join Date
    Dec 2008
    Posts
    2,529
    Nisswa, MN
    JD 3320 eHydro w/ 300CX Loader
    I think weight and tire type is going to determine how much disk you can pull.....not HP. I have owned a 790 and a 3320 and pulled a 5.5' KK tandem disk behind each. The extra weight of the 3320 makes the disc a joy to pull (even with Ind tires on the 3320 as compared to ag tires on the 790)....where the 790 would struggle. Your soil is going to be a big factor here too....but weight and traction (tire type) are also a big factor.
    Do not get a bigger disk than 5.5' IMO.....if you want to get some work done.
    3320 eHydro, 300CX Loader & 15 + great attachments
    You gotta mine allot of dirt to find a diamond.
Similar Threads
  1. john deere disc 105 6 foot disc, looking for parts
    By ROYCEWILLARDOKLAHOMA in forum Parts/Repairs
    Last Post: 03-12-2013, 11:31 AM
  2. Disc mower - whats with the cone on the far/end disc
    By aadawson in forum Attachments
    Last Post: 10-14-2012, 08:01 PM
  3. Farmpro 48 disc v.s. Agri-fab single row disc
    By BTackett in forum Attachments
    Last Post: 03-11-2008, 12:17 AM
  4. How big of a ploughing disc can I handle???
    By ncnewbie in forum Kubota Owning/Operating
    Last Post: 07-01-2007, 04:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
