Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Apr 2013
    Posts
    3
    Bonifay, Fl
    Kuboto
    Default Grain Drill
    Im not sure if this is the right place but i have a question. I just picked up an old Dohn Deere Model B Grain Drill. 8' 14 X 7. Not sure what 14 X 7 means but it seems to be in good condition but the gear (cog) on the right side that is on the end of a square tube that seems to be the main drive for the other gears. I hope i havent confused anyone. Anyway, it has worn or broken teeth on it and I cant seen to find anywhere to look for this and is there a way to get that off without a complete tear down? Any ideas from the pros?
  2. #2
    Platinum Member 3v0's Avatar
    Join Date
    Jan 2013
    Posts
    521
    Oklahoma Pan Handle, United States
    Kubota BX2200
    Default Re: Grain Drill
    I think 14 x 7 means 14 holes (drops) on 7 inch spacing.
    Try the JD dealer as I expect you may be able to get the parts and operating manual for it. Maybe try ebay too. But the JD dealer should let you point out the bad gear on his computer and order the part.
    When drills where out they work poorly. If the thing has been sitting you might want to tear it down and check the bearing etc, that gear may be broken because something else is wrong. Just a suggestion.
    Happy seeding
  3. #3
    New Member
    Join Date
    Apr 2013
    Posts
    3
    Bonifay, Fl
    Kuboto
    thanks
  4. #4
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    6,978
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Yes 3vO has it correct 14 seed openings spaced 7" apart. To replace the gear in question(parts key #3 2nd photo) one has to remove the grain box end cap plus the cast iron support in 1st photo. I remember back when I worked fior a JD dealer and had to assemble those model drills. Oh for the "good ole days". The gears in the 3rd photo have a hitory of wearing out with a lot of use also.Parts key #3 H209M 18T GP DRV GEAR ON JACKSHAFT ADD 74.15 USD
    Attached Thumbnails Attached Thumbnails Grain Drill-capture-jpg   Grain Drill-capture-jpg   Grain Drill-capture-jpg
Similar Threads
  1. My new grain drill is here!! Help!
    By HCJtractor in forum Attachments
    Last Post: 02-21-2012, 08:54 AM
  2. Seeders which and what grain drill
    By donais in forum Attachments
    Last Post: 08-29-2010, 12:14 AM
  3. JD Grain Drill
    By TexasDefender in forum Buying/Pricing/Comparisons
    Last Post: 03-17-2008, 06:59 PM
  4. Grain Drill vs. Grass Drill
    By bota7800 in forum Attachments
    Last Post: 02-26-2008, 09:54 PM
  5. grain drill
    By jiminpa in forum Attachments
    Last Post: 10-05-2000, 06:37 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
