3-Point Hitch 3 pt. lift problem
   / 3 pt. lift problem #1
Gurney1010
Pikeville, TN
John Deere 5400
I have a John Deere 5400 with a 520 loader. The hydraulic system is working fine in every area except the 3 pt. lift arms. The arms will not raise, they were locked in the up position with the drop rate valve, but when I opened it they dropped and will not raise. I have removed the drop rate valve, checked it out and could not see a problem. I have worked both the lift and draft levers in about every position and combination possible to no effect. Can anyone give me any direction in this matter? Any help would be appreciated. The loader works off of dual remote rear valves and it is working properly. I can notice no load added to the engine when the 3 pt levers are moved.
2020 DRAGON ESP...
2005 Suzuki King Quad 700 Fourwheeler (A57453)
2005 Suzuki King...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57453)
New/Unused AGT...
2013 KENWORTH T880 HYDRO EXC VACUUM TRUCK (A59823)
2013 KENWORTH T880...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
New/Unused AGT...
