JD 3320 Wheel Weights - Help
   / JD 3320 Wheel Weights - Help #1
El Wood
Gold Member
Michigan
JD 3320
I just recently picked up some wheel weights for my JD 3320. Initially my dealer said I could only do 2 50 lbs weights per side but then he said 3 is okay. I ended up getting 3 per side. I asked him about a starter weight but he said there is no need for one. Does anyone have JD weights on their 3320? I have R4 tires. I want to be sure I'm putting them on right. A few pics of your wheels or advice would be great. Thanks
I've got a lot of hardware also. Two different size bolts, nuts and lock washers. Anybody have these weights or can help?????
   / JD 3320 Wheel Weights - Help #4
Personally, I would add some flat washers in there also.
Thank you Willl. The pics were perfect and what I needed.
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57453)
New/Unused AGT...
SHOPBUILT SINGLE AXLE MOTORCYCLE TRAILER (A58374)
SHOPBUILT SINGLE...
2004 DITCH WITCH 3700 RIDE ON TRENCHER (A52709)
2004 DITCH WITCH...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
207273 (A52708)
207273 (A52708)
