Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    New Member
    Join Date
    May 2013
    Posts
    3
    Addison, VT
    2006 John Deere 2520 Compact
    Default 2520 starting and stalling
    I have a 2006 2520 compact with about 640 hours. While mowing it shut down, and would not restart and stay running. I could start it, it would run for about a second, and quit. Tried again a little while later, started right up and I mowed for another hour or so. Tonight, went to start it, and it fires and immediately stalls. Tried to start about 40 times, stalls every time, won't stay running. Disabled seat switch just for testing purposes, still not starting. HELP PLEASE!!!
    Thanks.
  2. #2
    Join Date
    Jun 2012
    Posts
    190
    west central IL
    John Deere 2520
    Default Re: 2520 starting and stalling
    Mine died on me spraying the yard the other day. I was moving along top speed on the low side and it was just like the key was turned off. I had to restart it and no problem since.
  3. #3
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,090
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    How long since fuel filter was changed? I also suggest to check fuel flow from tank. Have you checked operation of fuel control solenoid?
  4. #4
    New Member
    Join Date
    May 2013
    Posts
    3
    Addison, VT
    Quote Originally Posted by Tx Jim View Post
    It started this morning, changed the fuel filter anyways. Mowed for about 45 minutes tonight, and it died. Replaced the filter again, just for grins, still wont start. Just fires and dies.
    Whats the best way to check flow and how do I check the fuel control solenoid?
  5. #5
    Elite Member
    Join Date
    Dec 2000
    Posts
    2,968
    Southern VT, Southern ME
    John Deere 4100 HST /410 FEL, R4s
    If the 2520 works similar to a jd4100 you should hear a loud click when you turn the key switch to ignition. That is the fuel solenoid engaging with power from the fuel relay switch.
  6. #6
    Join Date
    Sep 2006
    Posts
    661
    Fairmont, WV
    '17 2032r (soon)
    The fuel from the tank should be gravity fed, that is assuming I am not an idiot tonight, so if that is true, disconnect the line feeding into the fuel filter and see if it flows. If it doesn't then you either have garbage in the line or there is something in the tank. Being 7 years old, I would think there could be some gunk in the tank and in the lines. If you have too little flow, hoping not to start a firefight, but if the lines have grime in it from old fuel and diesel bugs, a good fuel treatment could help, but you might be replacing the lines and cleaning the tank.
    As for past the fuel filter, testing the flow, well I know I am the idiot there, but I am sure if you follow the fuel line from the fuel filter to the engine, you can find a place where you could disconnect it and see if there is flow when the ignition is on or when you are trying to start it.
    Brian
    2008 2500HD CC SB Duramax 6.6L
    2016 900S RZR
    2017 John Deere 2032R, FEL, and 60D belly mower, 6 foot box blade, 6 foot rear blade, a set of pallet forks, a 5 foot brush hog.
  7. #7
    Join Date
    Jul 2008
    Posts
    75
    Wisconsin
    JD M, JD B, JD A, JD 50, JD 60, JD 420 JD 530, JD 630, JD 1010, JD 1010 Crawler,JD 3020G, JD 3020D, JD 2520 Compact Utility, JD 4720 Compact Utility
    Default
    You may have a plugged fuel tank vent. When the tractor stalls loosen or remove the fuel cap and see if it starts and runs ok. If it does, replace the cap.
  8. #8
    Join Date
    Jan 2007
    Posts
    7,090
    Coyote Flats,Tx
    You may have a plugged fuel return line,disconnect it and see if fuel comes out. I had an orange tractor I had bought used with the same type water separator filter(parts key #9) that had a tiny white screen in it plugged with debris and it wouldn't run right until I removed the screen.
    Attached Thumbnails Attached Thumbnails 2520 starting and stalling-m7291__________un01jan94-gif
  9. #9
    New Member
    Join Date
    May 2013
    Posts
    3
    Addison, VT
    Thanks for all your help.... I had to take it to the local dealer today, turns out it was the diode for the fuel solenoid. It was a 9 dollar item, but a couple hours labor. It DOES seem to be running properly now though.
  10. #10
    Elite Member
    Join Date
    Dec 2000
    Posts
    2,968
    Yea seems diodes are being used on certain circuits in the newer models. I believe the charging circuit has one also
Similar Threads
  1. Starting a JD 2520
    By revitupfaster in forum John Deere Owning/Operating
    Last Post: 12-09-2010, 06:43 PM
  2. 2520 stalling...?
    By Jksnvly in forum John Deere Owning/Operating
    Last Post: 07-10-2009, 01:27 PM
  3. 2520 stalling
    By ckiii700 in forum John Deere Owning/Operating
    Last Post: 01-08-2009, 10:35 PM
  4. Starting my 2520
    By Piedmont in forum John Deere Owning/Operating
    Last Post: 08-10-2007, 02:35 PM
  5. B7800 problem with starting and stalling- advice pleasee
    By Northland in forum Kubota Owning/Operating
    Last Post: 12-26-2006, 11:06 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
