Page 3 of 9 FirstFirst 123456 ... LastLast
Results 21 to 30 of 83
  1. #21
    Super Star Member Kyle_in_Tex's Avatar
    Join Date
    Oct 2002
    Posts
    10,148
    Giddings, Texas
    JD 4310,JD5420
    Default Re: Is mowing a pasture supposed to be this hard?
    Just wait to you hit that bigger chunk of metal that has been lying half buried there under the grass...1st time pasture mows are always a gamble. I've even tried lowering the FEL bucket to about 4" off the ground but got skeered thinking it might hit something and throw me over the front.
    I hit a piece of half buried "man walk" grate that did a number to our bush hog while trying to do a favor for our old church. They have 13 acres and need it shredded a few times a year. I was the guinea pig.
    HP/mower size....I like about 8Hp per blade foot if possible. Otherwise, you just have to slow down and work with what you have. I am surprised that anyone would rent out a batwing considering all the things that can go wrong. Usually when someone has to rent something like this, it's because their pasture is overgrown and has saplings/brush etc. This is tough on a mower if you think about the wear and tear of mowing something that hasn't been mowed in a while.
    A 7' foot shredder happens to have about the largest blade system available. I mean that most people jump up from a 6' to an 8' or 10' with dual blades. The huge 20' batwings use the 7' blades but they are aimed at mowing down corn stalks, not for stump jumping and cutting down heavy brush. If you think of the additional torque that can be applied to a 7' blade over a 5' or 6', it is quite a bit more. I would recommend that you just take it easy in B3 gear for the first cutting and keep a close eye out for objects.
    You need to get that tranny error code problem fixed. Better luck soon!
    Over-worrying about something is like putting a down payment on trouble.
  2. #22
    Veteran Member Lou66's Avatar
    Join Date
    Nov 2012
    Posts
    1,390
    Brazoria county where Texas began
    Deere 990/Montana 5740
    Well Corey I was going to mow today,, have about 70 A I need to knock down.. but after reading your post I may wait.. today is to pretty to get upset.. Just joking but not about the mowing,, that has got to be done.. Good luck on the rest of your cutting.. Lou
    "Life is good if beer is cold"
  3. #23
    Join Date
    Oct 2009
    Posts
    2,097
    Jefferson County, Mo, ... about 35 miles out of St. Louis.
    Bobcat 235, Gravely ZTR.
    Sorry to hear your problems. Like many said ... it happens. And I thought I had problems when the PTO belt broke on my ZTR last Thursday!
    MoKelly
  4. #24
    Join Date
    Feb 2012
    Posts
    732
    Germanton, NC
    Kubota MX5100F IH McCormick Farmall 140, Massey Ferguson 135
    +1 on having days like that. There are hard days on the farm but the worst days are still mostly pretty good. In answer to your question, no it isn't supposed to be that hard - but it is some days. The way I deal with hard days is try to be patient, work steady and persevere. Eventually things will smooth out and get easier.
    It is good to vent here because most of us have been there. Good luck!
  5. #25
    Platinum Member corey9212's Avatar
    Join Date
    May 2010
    Posts
    740
    Red Deer County, AB
    2015 John Deere 3046R
    Default
    Quote Originally Posted by TripleR View Post
    No, it's not "supposed" to be that hard, but as mentioned sometimes it just is and is the nature of farming, we had two fairly new tractors toes up last week for a coupe of days; nothing serious just annoying. Lots of good feedback on slip clutch etc., be thankful it was a U joint and not a gear box, we had that happen and $400+ down the drain.
    Not related, but a small cutter is a waste on that tractor or at least it seems so to me.
    Running tractors you will have good days and bad, just the nature of things, don't get too frustrated.
    I am glad that it is just the slip clutch and not a gear box, bigger tractors are nice but when something happens the problems are bigger as well, lol. I agree the cutter is a little small but it's only temporary, once the pasture is maintained I will be harrowing and baling it.
    Quote Originally Posted by Kyle_in_Tex View Post
    I already found the small rock pile that was hidden in the grass, that wasn't fun. I can see how it's tough on the mower, some of those mole hills were well established. I will mostly spend my time in B3 unless I hit an area that's well eaten down.
    Quote Originally Posted by Lou66 View Post
    Lol, I know what you mean, just waiting for the mechanic to show up then I'll be in the pasture again mowing. Thank you and good luck to you too.
    - 2015 John Deere 3046R
    - H165 Front End Loader w/73" HD bucket
    - 72D Auto Connect MMM, John Deere 375A Backhoe w/18" bucket, John Deere 59" Front Mount Snowblower, Frontier DH1296 8' Disc Harrow, Frontier SS2067B Poly Broadcast Spreader, Frontier AP12F Pallet Forks, John Deere 3PT Trailer Mover, Maybridge 12' Drag Harrow, 55 Gallon Spraytech 3PH Sprayer, 90 Gallon Water Carrier, 3 point bale spear
  6. #26
    Join Date
    May 2010
    Posts
    740
    Red Deer County, AB
    Default
    Here's a pic of the other side that I was mentioning earlier
    Attached Thumbnails Attached Thumbnails Is mowing a pasture supposed to be this hard?-image-1587706268-jpg
  7. #27
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,800
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Quote Originally Posted by corey9212 View Post
    Man that is broke alright, something didn't slip like it should. I ran into a pile of target stands, wire, tires etc. last year with our M8540 and DS1260, if something hadn't slipped it would have been very, very ugly. Yes, I have grand kids.
  8. #28
    Super Star Member
    Join Date
    Dec 2003
    Posts
    11,644
    NC
    Kubota Grand L3830
    Were or did you activate the rotary cutter at low RPM's or high RPM's? Activating the rotary cutter at high RPM's on a high torque engine will result in something having to give in the PTO drive. The rear universal joint could have been the weak link that gave and saved expensive damage. A seven foot rotary cutter is a lot of dead weight to suddenly bring up to 540 PTO RPM.
  9. #29
    Super Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
    Ouch...! Sorry to hear about your "perils of pasture" mowing!!! Nothing quite like those lurking "gotchas" buried in the grass! Hopefully, you'll get that clutch adjusted for the next cutting.
    Any further word on the transmission code? I think that would bother me more than the wire, gopher mounds and broken U-joints. That new, smoke breathing 115hp tractor shouldn't be doing that..
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
  10. #30
    Super Member
    Join Date
    Jul 2009
    Posts
    8,425
    SW WA
    Kubota BX2360
    pas·ture /ˈpasCHər/
    Noun
    Land covered with grass and other low plants suitable for grazing animals, esp. cattle or sheep.
    Animals are supposed to mow the pasture.
    Bruce
Similar Threads
  1. Is chipping supposed to be this hard??
    By jgrreed in forum Attachments
    Last Post: 10-22-2010, 08:00 PM
  2. Pasture Mowing
    By catskinner in forum Attachments
    Last Post: 06-09-2010, 06:57 PM
  3. Mowing Pasture
    By Believer in forum Rural Living
    Last Post: 08-07-2009, 01:02 PM
  4. Mowing Pasture Mowing
    By 0654 in forum Owning/Operating
    Last Post: 02-24-2004, 01:35 PM
  5. Mowing What's a field supposed to look like after mowing
    By swashbu in forum Owning/Operating
    Last Post: 06-12-2002, 01:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
