Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Super Member greg_g's Avatar
    Join Date
    Dec 2003
    Posts
    6,086
    Western Kentucky
    JD3720 Cab, 300X loader with 4-in-1 bucket
    Default Re: setting sway stabilizers on 3pt lift
    The 3x20 has spring tension already built into the sliding side stabilizers, so - when pinned correctly - there's no need to "add" additional slack. After mounting an implement and centering the arms, pin the holes that make themselves available while there is yet no tension on the springs. That way - once pinned - the stabilizers are free to sway within the limits of the tension springs, which coincidentally is probably pretty close to the aforementioned inch.
    USN (Ret)
    Former Chinese tractor owner (x4)
    Current John Deere owner
  2. #12
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,167
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Quote Originally Posted by greg_g View Post
    I don't see the spring in the adjustable stabilizers that you refer to. A spring isn't listed in the parts breakdown.
    Attached Thumbnails Attached Thumbnails setting sway  stabilizers on 3pt lift-lvp7677________un27nov06-gif
  3. #13
    Join Date
    Apr 2013
    Posts
    68
    texas
    john deere
    I would like more info on the springs as well. Mine doesn't have them
  4. #14
    Join Date
    Dec 2003
    Posts
    6,086
    Western Kentucky
    I stand corrected, should have used the word "slot" instead of "spring". Mine have a rectangular cross section, and consist of (a) a solid bar that's pinned to an axle housing bracket, one for each side and (b) a rectangular tube/sleeve that slides over the bar, again one for each side. The sleeve is attached to the lift arm, again one for each side. There are four pin holes in each bar, 3 holes and a 1.685" slot in each tube. When you want positive engagement, you align a tube pin hole with the appropriate bar pin hole, pin hole to pin hole. When you want that "inch of slack", you center the slot in the sleeve over the appropriate pin hole on the bar; slot to pin hole.
    //greg//
    USN (Ret)
  5. #15
    Join Date
    Jan 2007
    Posts
    7,167
    Coyote Flats,Tx
    greg_g
    I'll bet your tractors sway bars look very similar to the parts photo I posted. I've wondered why it took tractor engineers so long to design something so simple. The 2000 model orange tractor I did own was the 1st sway setup I'd seen and after using them I liked the stabilizers.
Similar Threads
  1. Lift Arm stabilizers
    By Chain Bender in forum Attachments
    Last Post: 11-27-2011, 10:37 AM
  2. 3-Point Hitch Adding anti sway stabilizers?
    By ElmerPhudd in forum Owning/Operating
    Last Post: 11-21-2011, 08:32 AM
  3. 3pt Hitch Sway Stabilizers
    By TheHardWay in forum Build-It Yourself
    Last Post: 02-28-2011, 12:36 AM
  4. Lift Arm - telescoping sway bars
    By subzero in forum Customization
    Last Post: 03-26-2008, 04:25 PM
  5. Lift Arm - telescoping sway bars
    By subzero in forum Build-It Yourself
    Last Post: 01-07-2008, 09:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
