I got a john deer 955, it has a yanmar diesel. It ran a 6+ months ago when it was parked, but now i cannot get it going to save my life. I get fuel to the injector pump but am not getting fuel to go threw the injectors. I cant understand how the pump could go bad form sitting, it did seem to have water in the fuel so i flushed it all out.
I took off the 2 clamps on the 3 injector line fitting, if you loosen those fuel will flow and i can prime it up to the injector, crank it over and get fuel to squirt out but cant get enough fuel pressure to fire the injectors it seems. It runs on starting fluid. This machine has been maintain so poorly I cant make seance of the wiring. The solenoid is not hooked up to fuel control I believe on is pulled back toward operator.
Thanks
Thanks
