Results 1 to 9 of 9
  1. #1
    Veteran Member jimgerken's Avatar
    Join Date
    Nov 2001
    Posts
    1,638
    Minnesota
    John Deere 3720
    Default 3720 update being installed
    The dealer called me and said they'd like to come and do an update to my 3720. Its out of warrantee, so I suspect the update is a safety item. I asked what it was, he told me they'd be pulling off the rear wheel and installing a gasket in/under a valve (rockshaft something maybe?). I can report more next week. I can't wait to see the service guy's face when he sees the wheel weights he gets to handle.
  2. #2
    Join Date
    Oct 2007
    Posts
    211
    SW Washington
    JD 3520 w/ 300CX
    Default Re: 3720 update being installed
    Curious what year yours is. This is a known recall issue, but I emailed my dealer a couple months ago to ask if mine was included, but my serial number was not in the range for the recall.
    2007 JD 3520, PR, 300CX
    2012 x300
  3. #3
    Join Date
    Nov 2001
    Posts
    1,638
    Minnesota
    John Deere 3720
    Oh, three or four years old. I am not sure where to look for that info, somewhere on a label on the tractor?
  4. #4
    Gold Member BigMike50's Avatar
    Join Date
    Mar 2013
    Posts
    391
    Uranus
    2012 JD 3520 Cab 1996 JD LX172 1985 Wheel Horse
    yeah that recall is for older models. Interesting they are doing it out of warranty. I would consider that a tsb and not a safety recall where they would have to fix it
  5. #5
    Veteran Member sunnyside360's Avatar
    Join Date
    Aug 2006
    Posts
    1,519
    Central PA
    JD 3720, JD 4320, Kubota M110X, Kubota ZD1511, Kubota RTV X1100C
    I have what I would consider an older model 3720 cab tractor which I ordered/bought new in 2007. My dealership started doing this fix over a year ago and mine was NOT included in his recall list. They double checked my serial number with John Deere after I asked and told me my tractor is definitely not included in the recall. I talked to the service guy doing the update and he said none of the old gaskets he removed to date were actually defective (that was last Fall). If I remember correctly, the problem/symptom was the 3 PH would leak down, ie, not hold position.
    Does anyone have a 3720 cab tractor that was recalled?? I was thinking maybe only older open station models were affected.
  6. #6
    Super Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
    It wasn't for leaking seals at the arm/transaxle?
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
  7. #7
    Join Date
    Aug 2006
    Posts
    1,519
    Central PA
    Quote Originally Posted by AKfish View Post
    AKfish
    Maybe for leaks also but I haven't seen those threads on the forum.
    There have been a number of threads on TBN about this topic. Here is an older/lengthy thread http://www.tractorbynet.com/forums/j...20-recall.html
    Some descriptions like this post from NURU "I had mine fixed in 2008, as the first time I put my flail mower on the tractor's 3PT, it started trying to dance and acting like it had the hiccups (shuddering and shaking pretty hard). I sent it to the dealer and they executed the warranty fix."
  8. #8
    Bronze Member Riderguy's Avatar
    Join Date
    Dec 2008
    Posts
    62
    The tractor is in NW Arkansas
    John Deere 3720
    I had mine ('09 3720) done the beginning of the year. The dealer not only did the work, but picked it up and dropped it off all free of charge. The warranty expired in October of 2012. Must have been have been some kind of safety recall.
    Scott
    Scott
    Deere 3720 w/CX300 FEL - IMatch - Frontier RC2060 cutter - Frontier BB2060 Box Blade - Ratchet Rake - HydrauLink - Artillian Pallet Forks
  9. #9
    Join Date
    Nov 2001
    Posts
    1,638
    Minnesota
    John Deere 3720
    It was the rockshaft valve cover gasket, on the left side of the tractor. No charge to me. They came to my farm and jacked it up on the cement in front of my shed. He had fun with the weights, but I helped him so it was tolerable. The gasket looked fine to he and I, and it probably was not leaking, although it was tough to tell for sure because everything is dirty after the top rockshaft cover had been loose ! and leaking a couple years ago. The new gasket looked the same as the old gasket, to me at a glance. He mentioned that he had to go back and do the paperwork that day yet, since the "program" ends Tuesday. Whatever that means. I never did find a year on my tractor.
Similar Threads
  1. Has anyone Installed and used one of these?
    By corey9212 in forum Attachments
    Last Post: 05-08-2012, 02:18 PM
  2. Replies: 17
    Last Post: 11-18-2010, 11:11 PM
  3. Has anyone installed a MMM by themselves?
    By TommyBoy77 in forum Bobcat Tractors
    Last Post: 07-17-2010, 09:43 PM
  4. FEL Installed
    By Eddie in forum Yanmar
    Last Post: 11-15-2006, 05:48 AM
  5. Mid PTO installed on 990
    By yellowsocks93 in forum John Deere Owning/Operating
    Last Post: 01-02-2006, 08:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
