Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Gold Member
    Join Date
    Oct 2007
    Posts
    455
    North Central Mississippi
    JD 5075E Cab
    Default Re: Help Me Diagnose an Engine Problem
    ***UPDATE***
    I had some type of AWFUL gunk in my tank that contaminated the entire fuel system and clogged 2 of my injectors. The shop manager saved the fuel he placed into 2 separate 20oz empty coke bottles. One looked like chocolate milk and the other looked like 75% watered down diesel and 25% light brown gunk. They have no idea what it is and have never seen anything like it before.
    I don't understand because I fill up the storage tank 2-3 times a year and use a golden rod filter. The only other fuel I use comes from the only place in town that sells off road diesel and they have a great reputation. What I am basically saying is that I only use fresh filtered fuel. John Deere suspects that the tractor/storage tank may have been sabotaged. The good thing is that Sentry Insurance is paying for all but the $500 deductible. The total cost was $4,519!! They replaced all the injectors. I ran the tractor today for the first time in 5 weeks and it ran great.
  2. #22
    Gold Member
    Join Date
    Oct 2007
    Posts
    455
    JD 5075E Cab
    Here you go....
    Help Me Diagnose an Engine Problem-image-1-jpgHelp Me Diagnose an Engine Problem-image-3-jpg
    Help Me Diagnose an Engine Problem-image-jpg
  3. #23
    Veteran Member kuboman's Avatar
    Join Date
    Dec 2009
    Posts
    2,278
    Canada
    B3200, L5740,
    Holy _ _ _ _!!! That isn't even diesel. Best check your storage, you have serious water contamination.
    L5740 LA854 loader
    L3130 LA723 loader sold
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    ZD1211
    GF1800 sold
    Kubota RTV900
    JD 850D Gator sold
    JD F935 x 2 sold
    Case 590SM-2
    JD 310D TLB sold
    Ford 555D sold
    Gehl 602 excavator sold
    JD317 sold
    JD323D
  4. #24
    Join Date
    Jun 2012
    Posts
    67
    winona mn
    jd2520
    you have any trash or brush to burn ? get rid of what you have left
  5. #25
    Gold Member
    Join Date
    Oct 2007
    Posts
    455
    JD 5075E Cab
    Trust me, I will not be using any diesel out of that old storage tank. I will just have to cut my losses. I have already purchased a new tank.
  6. #26
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,424
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    Quote Originally Posted by trook View Post
    I own a 2009 JD4320 with 565 hours. Earlier today, I noticed that the engine seems to be running a little "rough". By that, I mean that if it is idling and you depress the foot throttle, it feels a little "rough" as the engine rpm's increase and it feels like it is missing a little. It also feels like is has a little less power and sounds slightly different. Almost like a 8 cylinder gas engine with 1 cylinder missing.
    I don't notice this if I am at 1500 rpm and quickly accelerate to 2600rpm. It may have the same issue at the higher rpm's, but its hard to tell. If the issue is there, it is not as noticeable.
    Since the fuel tank was about 1/4 full, I decided to fill up with fresh fuel, but it runs the same.
    I didn't think the fuel filter would be the problem, but I changed it anyway. However, it didn't fix the problem. Also, the air filter is fine.
    Suggestions?
    It is not leaking fuel. If it is losing any power at pto speed, its not obvious. It appears to cut with normal power at pto speed. This evening, I was able to cut 5ft tall VERY thick grass. It bogged a little, but nothing I didn't expect.
    ***UPDATE***
    So, $4.5K later it seems fresh fuel, filters and a good additive would have fixed it. ...
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, CCM165 Drum Mower, JD Rake
    JD 127 bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
  7. #27
    Gold Member
    Join Date
    Oct 2007
    Posts
    455
    JD 5075E Cab
    Quote Originally Posted by SPYDERLK View Post
    Maybe..... except that fresh fuel, filters and fuel additives WERE used. Maybe you can identify the stuff in the bottles and tell me how it could have gotten through the golden rod filter on the storage tank, the 405 diesel treatment and the regularly changed filter on the tractor? John Deere and I would certainly like to know.
  8. #28
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,424
    VA
    The stuff got in your tank somehow unknown, but once there that is what the tractor was trying to burn. Fresh fuel would entail getting out the tank contents present at the start of problem behavior. Additives have their limit against a large quantity of contaminant at the fuel pickup. Once this was gone they would have had a chance to clear the lines as the engine ran.
    This side of 40
Similar Threads
  1. diagnose my air compressor
    By Haywire in forum Rural Living
    Last Post: 08-22-2011, 10:54 AM
  2. Oil & Fuel diagnose injector pump
    By Abe460 in forum Massey Ferguson Owning/Operating
    Last Post: 02-12-2011, 09:30 PM
  3. Diagnose My Compact 670 tractor
    By cartod in forum John Deere Owning/Operating
    Last Post: 07-27-2010, 06:04 PM
  4. Please Diagnose This Bad Noise
    By jc7622 in forum Montana
    Last Post: 06-21-2008, 06:57 PM
  5. mechanical problem - can u diagnose?
    By mdbarb in forum Kubota Owning/Operating
    Last Post: 08-18-2005, 10:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
