Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Super Member
    Join Date
    Nov 2003
    Posts
    8,384
    Central Michigan
    4210 MFWD Ehydro--'89 JD 318
    Default Deere plastic hood repair
    My 2002 4210, which has the plastic hood, suffered an impact to the immediate front and it badly cracked the first few inches of the top part of the hood. I priced a new one from Ebay and a replacment is about $285, plus the cost of replacing the side decals. Has anybody had experience with having their hood repaired and repainted by a body shop? Thanks for any input.
  2. #2
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,803
    Nova Scotia, Canada
    Default Re: Deere plastic hood repair
    Fiberglass resin and cloth just may work on the hood.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  3. #3
    New Member
    Join Date
    May 2013
    Posts
    22
    Somewhere out there
    John Deere X310
    I know I've read on the internet about a "plastic weld" kit, but I don't know how it works or how visable the repair would be. I'd contact a repair shop and see what they say, it doesn't cost anything for an estimate and they'll be able to tell you if the repair will show or not. But with the cost of labor being what it is I wouldn't be surprised if it will cost more to repair than to replace!
  4. #4
    Join Date
    Oct 2011
    Posts
    107
    Australia
    N/A
    I had the nose cone on my tractor plastic welded, it was broken into many little pieces so fibreglassing was not possible. The repair has lasted well. The method they used was to melt a plastic rod and fuse the cracks on the underside. I never bothered to have it cleaned up and repainted though.
  5. #5
    Elite Member
    Join Date
    Oct 2006
    Posts
    4,759
    Ohio
    GC2310,
    I repaired things like this in our body shop. Most of the time it can be done.
    The problem is, you are not going to get much of a repair for under $200, if it needs to be repainted. And, by the time you get to that point, you may as well get the new hood.
  6. #6
    Join Date
    Nov 2012
    Posts
    1,003
    Tennessee foothills
    John Deere and Case
    Do the repair yourself for less than $40.00 ,Youtube will show you how and materials are less than $40.00 from Tractor Supply it's not brain surgery !
  7. #7
    Platinum Member JDTank's Avatar
    Join Date
    Oct 2010
    Posts
    695
    Personally, I would suck it up and buy a new hood.
    The material John Deere uses is not fiberglass, nor is it plastic. I can't remember the technical name, but it's more like a space age plastic. This kind of material does not take well to patch jobs. Once you have one cracked area, it will usually continue to spread even if you try to repair it.
    It will never look the same no matter how good one tries to repair it. Personally, this kind of thing would drive me nuts. Order up a new hood and just shake your head!
    2012 John Deere X740
    #18 Steel cart.
    Front fender kit.
    Brush guard.
    SE seat.
  8. #8
    Join Date
    Nov 2012
    Posts
    1,003
    Tennessee foothills
    John Deere and Case
    Quote Originally Posted by JDTank View Post
    it's a tractor your not taking it to the car show or waxing it every weekend ,repair it and save your money for something worth it , like taking your kids fishing or camping for a couple days !
  9. #9
    Join Date
    May 2013
    Posts
    121
    Platteville, WI
    John Deere 1026R
    Quote Originally Posted by Grumpy Old Man View Post
    So, from a purely pragmatic view Ol Man Grumpy is right, do it yourself. You'll save money and the tractor will perform no differently than before the accident.
    For me, however, I'd do just what JDTank would do. I'd pony up the $285, 'cause it would bug the crap outa me until I replaced it. I try to keep all my equipment looking good, may not be pragmatic, but I take pride in keeping things looking good. That's just me, though.
    If the appearance matters, spend the $285. If it makes no difference to you, spend the $40, do it yourself, not worrying if it looks good or not.
  10. #10
    Join Date
    Jun 2008
    Posts
    130
    Northern Virginia
    John Deere 2720, John Deere GT225, GX345
    Some may not like this repair but it was cheap and has held up. It could use a fresh coat of green duct tape.Deere plastic hood repair-137-jpg
Similar Threads
  1. JD Plastic Hood
    By jandlcars in forum John Deere Lawn & Garden
    Last Post: 04-17-2011, 09:50 PM
  2. BX1850 Plastic hood
    By Creek chub in forum Kubota Owning/Operating
    Last Post: 11-22-2010, 10:57 PM
  3. Cleaning the plastic hood question
    By 09 X540 in forum John Deere Owning/Operating
    Last Post: 02-24-2009, 12:00 PM
  4. Dimples on Plastic Hood
    By Engine66 in forum John Deere Owning/Operating
    Last Post: 08-06-2008, 01:02 PM
  5. Broken plastic hood?
    By GreatWhitehunter in forum John Deere Owning/Operating
    Last Post: 03-26-2008, 03:38 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
