John Deere 790 Fuel Solenoid
   / John Deere 790 Fuel Solenoid #1
jtaylor
Fayetteville tn.
790 John Deere Tractor
I have a 2004 Jon Deere 790 tractor. The issue is the 5 amp fuse blows to the fuel pump. I have notice that if I disconnect the connector going to the solenoid and turn the key to the on position the fuse does not blow. When I connect the solenoid and turn the key to the on position the 5 am fuse blows. Does anyone know how to check the fuel solenoid with a volt /ohm meter. I would like to know before the spend 180 bucks one a new solenoid. Any help would be appreciated.. Thanks..
   / John Deere 790 Fuel Solenoid #2
   / John Deere 790 Fuel Solenoid #3
Sounds like the solenoid may be bad, but before installing a new one make sure the old one did not fail because the Time Delay Control Module is bad. The TDCM should provide the pull-in voltage for no more than 1.5 seconds. Long term application of that high current will cause the solenoid coil to burn out.
2001 John Deere M665 (A50120)
2001 John Deere...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
MISSION 4X3X14 CENTRIFUGAL PUMP (A53843)
MISSION 4X3X14...
DRAGON 500 BBL FRAC TANK (A53843)
DRAGON 500 BBL...
2012 FREIGHTLINER DURASTAR 4300 M7 SBA 4X2 BUCKET TRUCK (A51406)
2012 FREIGHTLINER...
