Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    May 2002
    Posts
    5
    Default 4400 won\'t start/turnovr after stalling - HELP!!!
    HELP - My rented 4400 stalled while I was tilling - Operator (me) attacked by hornets and bailed after turning throttle down and stopping. It then proceeded to stall and I didn't return for 5 minutes. The key was on and the PTO engaged. I was able to disengage the PTO but now the engine won't even turn over. HELP PLEASE The rental place is closed until Monday!!
  2. #2
    Veteran Member Mark_in_NH's Avatar
    Join Date
    Mar 2002
    Posts
    1,567
    Moultonborough, New Hampshire
    New Holland TC35D w/ 16LA FEL
    Default Re: 4400 won\'t start/turnovr after stalling - HELP!!!
    </font><font color="blue" class="small">( It then proceeded to stall and I didn't return for 5 minutes. The key was on and the PTO engaged )</font>
    My first asumption is that it stalled, because when you got off the seat you opened a safety switch, and the battery went dead because the key was left on.
    Check battery and connections. The PTO you have disengaged, so that shoudn't be an issue.
  3. #3
    Join Date
    May 2002
    Posts
    5
    Thanks for the quick response. I was thinking that because the lights and gages are wrking that the Battery was o.k. But now that you mentionit i think I've burnt myself by that thought before. Replacing starters because of a battery problem. I will give it a tryafter the swelling goes down. Thanks again!
  4. #4
    Join Date
    Mar 2002
    Posts
    1,567
    Throw a set of jumper cables on her, and see if she fires up !!
  5. #5
    Join Date
    May 2002
    Posts
    5
    Tried the jumpers and still nothing. Lights don't even dim when you turn the key. Could it be some fuse or other inter-lock safety thing I don't know about? The PTO dash light is out but it does not spin freely. Only about a quarter turn before a positive metal on metal stop.
  6. #6
    Join Date
    Mar 2002
    Posts
    1,567
    Seems like maybe the PTO lever is in a disenaged position but the PTO itself may not be disengaged. I guess if it were me in this situation, I would put the tractor in neutral and try to move it, most likely by putting a chain on it to my truck and giving that tractor a little tug. It might be just enough movement, to allow the gears to release.
    Now if this is a hydro tractor, the above may or may not work. I am still learning about hydro's.
  7. #7
    Join Date
    May 2002
    Posts
    5
    Just got done checking all fuses. Still won't crank. I agree with giving it a little tug to see if anything "breaks" free. I take it from your response the PTO should spin freely when disengaged. It will have to wait until tomorrow though. Thanks again for your help.
  8. #8
    Veteran Member BillyP's Avatar
    Join Date
    Dec 2002
    Posts
    1,769
    Eagletown, OK
    JD 4610 ehydro MFWD
    If it's a gear drive, put it in neutral. And no, the PTO won't spin freely when disengaged.
  9. #9
    Join Date
    Jul 2003
    Posts
    798
    Southeast Indiana
    JD2210
    I would say it is something being over looked.
    Step back and recheck everything.
    Neutral
    PTO off
    Brake on
    In seat?
    Check switch under seat, maybe broke when fast exit!
  10. #10
    Platinum Member Trev's Avatar
    Join Date
    May 2002
    Posts
    913
    Williamson, NY (near Rochester)
    Currently tractor-less
    Is this a manual? Is your "shuttle" (forward, neutral, reverse) lever in neutral? This one tripped me up once... even if trans is in neutral, that reverser lever has to be in neutral also.
    Bob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
