3320 error 08
   / 3320 error 08 #1
tervete
Member
Martintown, ON, Canada
JD 3320
my first tractor, got it last Friday. A used 2009 JD 3320, it has error 08 showing up. How do I fix this?
   / 3320 error 08 #2
I have a PDF of the tech manual you're welcome to, just shoot me your email
Joe
your #08 error -
Err 08 Throttle Sensor Voltage signal out-of
range or not calibrated.
No anti-stall function;
Loss of performance.
Calibrate the sensor. Check the
sensor and 499 Wht wire and
connections.
   / 3320 error 08 #3
From the owner manual:
"Err 08
Throttle Sensor.
Voltage signal out-of-range or not calibrated.
No anti-stall function; Loss of performance.
Contact your John Deere dealer.
//greg//
   / 3320 error 08
I got the tech manual (tx Joe) and it was easy to fix. Getting in the diagnostic mode was easy and adjusting the throttle sensor was also easy.
Tx.
Pauly
   / 3320 error 08 #6
Joe
your #08 error -
connections.
Same issues as tervete. Have yet to find a guide to the solution via the internet.
I was contemplating the $340 on the JD tech manual but was reluctant to do so if the fix was beyond my capabilities. So worst case, 340 + JD service fee was not what I would call a win.
Would you be willing to share the .pdf as you offered tervete?
08 challenged.....
   / 3320 error 08 #7
Check your messages
2017 Hino 268 26FT Box Truck (A53422)
2017 Hino 268 26FT...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
Man Basket Forklift Attachment (A55851)
Man Basket...
HIGH-END MINI GOLF CART (A55745)
HIGH-END MINI GOLF...
MISC CABINETS FLOORING (A54757)
MISC CABINETS...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
