Fixin4fun
Here's my 2 cents: The emissions are typically tied to the WOT speed, not the low idle. That's why it (high idle setting) has a permanent tag to identify if someone tampers with it. Low idle is determined off of noise and performance as engine is tied to the hydraulic and hydrostat pumps and can be adjusted by the low idle screw and lock nut. The lower the engine speed, the lower hydraulic flow, so steering and hydraulic performance will be lower. As long as you are aware of the steering and hydraulic issues, I say adjust to your liking. Yanmar has been building those small diesels for quite some time and I would find it hard to believe they'd build one that would self destruct due to lack of oil.
