Results 1 to 9 of 9
  1. #1
    New Member
    Join Date
    Sep 2013
    Posts
    3
    Saskatoon, Sk
    8450 John Deere
    Default J D 8440 always hard to in summer
    8440 J D will start in the same day Ok when u get it going but by the next day
    it is back to being real stubborn --forget about winter starts .. we put an
    electric lift pump between tank and injector pump as per J D dealer suggestion
    but it hasn't helped at all. The pump just will not let fuel in until turning
    the engine over for 10 minutes and using starting fluid aids or bleeding injector
    lines every time. Any suggestions??
  2. #2
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,052
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: J D 8440 always hard to in summer
    Sounds as if you need to check the operation of the fuel check valve. AR73888 Check Valve ADD 44.75 USD
    Attached Thumbnails Attached Thumbnails J D 8440 always hard to in summer-rg1175_________un01jan94-gif
  3. #3
    New Member
    Join Date
    Sep 2013
    Posts
    3
    Saskatoon, Sk
    8450 John Deere
    HI, Tim Thanks very much for the info --- Is it located at back of injector pump? thks, Ron
  4. #4
    Join Date
    Jan 2007
    Posts
    7,052
    Coyote Flats,Tx
    I think it's attached to filter base but I'll have to do some research.
  5. #5
    Veteran Member kuboman's Avatar
    Join Date
    Dec 2009
    Posts
    2,276
    Canada
    B3200, L5740,
    It is attached to the inlet of the filter base. There is also a checkvalve/pressure regulator on the outlet of the injection pump. If either of those are faulty you will get fuel bleedback from the pump making for difficult starting. Also make sure that all you fuel lines on secure. If you have any rubber lines replace them. If they leak air then you will have bleedback too.
    L5740 LA854 loader
    L3130 LA723 loader sold
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    ZD1211
    GF1800 sold
    Kubota RTV900
    JD 850D Gator sold
    JD F935 x 2 sold
    Case 590SM-2
    JD 310D TLB sold
    Ford 555D sold
    Gehl 602 excavator sold
    JD317 sold
    JD323D
  6. #6
    Join Date
    Jan 2007
    Posts
    7,052
    Coyote Flats,Tx
    kuboman
    Can you please point out the check valve at inj pump as I don't remember one?
    Attached Thumbnails Attached Thumbnails J D 8440 always hard to in summer-mp12543________un01jan94-gif
  7. #7
    Veteran Member jimmysisson's Avatar
    Join Date
    Jul 2005
    Posts
    2,344
    W.Mass
    1993 NH 2120 (the best), 1974 MF 135 (sold, but solid), 1947 Farmall A (bought, sold, bought back, sold again), 1956 MH50 lbt (sold, in 1980, darn it)
    Default
    I'd be keeping an eye on the starter too if you normally crank it that long. I'd want ten seconds max, not ten minutes.
    Jim
    "Anything worth doing is worth doing slowly" Mae West
  8. #8
    Join Date
    Dec 2009
    Posts
    2,276
    Canada
    B3200, L5740,
    Quote Originally Posted by Tx Jim View Post
    kuboman
    It is #13 in this page shot. It is called a control valve.
    J D 8440 always hard to in summer-rgp2710________un01jan94-gif
    L5740 LA854 loader
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    ZD1211
    GF1800 sold
    Kubota RTV900
    JD 850D Gator sold
    JD F935 x 2 sold
    Case 590SM-2
    JD 310D TLB sold
    Ford 555D sold
    JD317 sold
    JD323D
  9. #9
    Join Date
    Dec 2001
    Posts
    1,336
    Maryland
    Item #5 in this picture is the check valve at filter base.
    Attached Thumbnails Attached Thumbnails J D 8440 always hard to in summer-rgp2295________un01jan94-gif
Similar Threads
  1. In product comparison which one is better, the Deere 8440 or the Deere 9560R?
    By greenmachine86 in forum John Deere Owning/Operating
    Last Post: 09-23-2011, 06:39 PM
  2. JD 8440 PTO
    By Ray Apinall in forum John Deere Ag Tractors
    Last Post: 08-04-2011, 11:25 PM
  3. 8440 3 pt
    By markort in forum Hydraulics
    Last Post: 05-15-2011, 11:07 PM
  4. What did you do this Summer ?
    By KiotiKevin in forum Projects
    Last Post: 11-10-2004, 06:40 PM
  5. Last summer
    By Dozernut in forum Photos
    Last Post: 02-24-2003, 02:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
