Results 1 to 5 of 5
  1. #1
    Join Date
    Jul 2002
    Posts
    64
    Ortonville, MI
    Deere 3320 w/eHydro
    Default Switched 3320 R3s to wide position.
    Looks to be about 3-4 inches/side. Forgot to take 'before' pics of the fronts. I should be able to see the loader arms better with the fronts wider when switching out bucket to blade to forks.... The fronts and rear look to be the same overall width now - the pic makes the front tire look wider.
    Waiting for weather to cooperate and power to come back on so I can get new tractor pics posted.
    Attached Thumbnails Attached Thumbnails Switched 3320 R3s to wide position.-image-jpg   Switched 3320 R3s to wide position.-image-jpg   Switched 3320 R3s to wide position.-image-jpg
  2. #2
    Platinum Member JD 4520's Avatar
    Join Date
    Apr 2011
    Posts
    851
    NW WA
    John Deere 4520
    Default
    Looks good, the whole tractor does. Like to see ow that wide position works in the snow. Is that why you went wide or do you have hillside that you traverse?
    Gary
    JD 4520, 400X FEL, Frontier Front Blade, Box Blade, Rotary Cutter, Landscape Rake, 48" Wildkat Grapple and PHD
  3. #3
    Join Date
    Jul 2002
    Posts
    64
    Ortonville, MI
    Deere 3320 w/eHydro
    Default Re: Switched 3320 R3s to wide position.
    Some slopes that I have at home and many slopes where we keep our camper all summer. I don't need to mow on side hills, but I was hoping wider would give me more accessibility to some of the property. Here's a size comparison to the 1026R that I traded in and snow blades installed.
  4. #4
    Veteran Member Rockgod's Avatar
    Join Date
    Oct 2010
    Posts
    1,373
    CNY
    JD Cabbed 3720
    Looks good!
    JD 3720 Premium Cab, 300CX, 59" Front Mt. Blower, 72d MMM auto-connect deck.
  5. #5
    Veteran Member CinderSchnauzer's Avatar
    Join Date
    Apr 2006
    Posts
    1,407
    Very nice set up. I really like the front blade.
    2007 JD CAB 3320 eHydro, 300CX FEL, GX720 Back Hoe, 72" 7-Iron MMM, 48" Horst Pallet Forks
    Lucknow 60" Rear Snow Blower, JD Box Blade 2065
    2013 JD X739 - 60" HC Deck with Auto Connect
Similar Threads
  1. 2520 Wide Position Rear Wheels
    By TNTractor1 in forum John Deere Owning/Operating
    Last Post: 12-21-2011, 08:43 AM
  2. switched tires to 'wide' - now leak?
    By wango tango in forum John Deere Owning/Operating
    Last Post: 07-13-2011, 09:38 PM
  3. Tires Moved tires in rear to wide position.
    By xrjohndeere in forum John Deere Owning/Operating
    Last Post: 05-08-2010, 07:31 PM
  4. How WIDE is the 3320 or 3720 JD tractor
    By Ramairfreak98ss in forum John Deere Buying/Pricing
    Last Post: 03-02-2006, 12:14 PM
  5. 60" 7 iron deck on a 68" wide 3320 series tractor?
    Last Post: 02-11-2006, 10:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
