Did some research(google) and found the danfoss pdf parts list and diagram for these steering valves. My local hydraulic repair shop ordered it for me, cost $75.00. Danfoss part #150L4054
This is how i repaired it...
Removed steering valve and marked side with paint marker where it seperates. Use a pick and remove dust seal on steering shaft. Took a picture of where the fittings are, one is a blank, two small and two large ports. The fittings thread in and hold the two halves together. Once you get the fittings out, yu can pull the two halves apart. Keep the valve upside down, if you turn it up like it fits in the tractor it will fall apart. I used my table that has a hole it for the steering shaft to fit thru. While removing the half the fittings came out of make sure the driveshaft comes with it and do not turn it. Lay it in a safe place. Now you can push the steering shaft up and out. There is a bearing and two washers that have to come out then you can remove the blue colored seal with oring. Install the new seal ( i used my fingers to press it in) and reassemble.
Attached pdf i found and a picture of seal kit.
Hope this helps someone else.
