aondre
Member
- Joined
- Dec 21, 2000
- Messages
- 38
- Location
- Wisconsin
- Tractor
- JD 4100, (2) JD 4400s, Gehl 5635DXT Skid Steer, Gehl 7800 Skid Steer, JD 110TLB
I have the 47" front snowblower mounted on my 4100. About 12" from where the shaft connects to the tractor, the shaft appears to be slightly rubbing on what looks like a cooling line. When the PTO is off, there is about a 1/16" clearance between the shaft and line, however it must be rubbing while it is turning because the metal cooling line is wearing thin.
The blower and the shaft were purchased used from a JD dealer, and I noticed the shaft was a little rusted in almost the same spot it is rubbing on my machine, like it probably happened to the previous owner.
Has this happened to anyone else? Is this poor JD design or is the u-joint in my PTO shaft getting too worn? I also don't see any obvious adjustments I can do on the quiktatch to lower the shaft, are there any?
