netwayne
This little tractor has been excellent since we purchased it new in the Fall of 2008. Only thing I've had to do outside of the recommended service intervals is replace a battery a couple of years ago. This tractor gets used almost daily but for generally short times. We just hit 200 hours on it and it is 5 1/2 years old. This past week we have started to notice a problem when starting. It turns over just fine but has a little trouble staying running and then when it does has a little bit of a rough idle and sounds like it is going to quit. For the most part after a minute of so, it seems to clear but it has quit on us a couple of times shortly after starting. Couple of thoughts came up for me on this and thought I would make a post to get some feedback.
The way this issue appears makes me think it might be a fuel issue. I have yet to change the fuel filter on the machine and when we just hit 200 hours, I pulled the owner's manual out and see that the fuel filter isn't due until 400 hours. Seems like a long time out for a low usage machine. I have a replacement filter that came in a maintenance kit so thinking about replacing that early. Curious how others feel about the service interval for the fuel filter. Was also curious if anyone is doing any kind of fuel treatment for these diesel tractors? We run a diesel kleen product through our Ford F-350 which does help out with water in the fuel and since using that product, I haven't had to drain water from the truck.
Lastly, I have been reading about similar issues in the 2305's relating to a V4 Diode failure. I am going to purchase the technical service manual to have more information at my disposal.
Appreciate any feedback on what I have mentioned here today. Thanks!
