buck4779
I have a JD 5105 4 WD. I just changed the hydraulic fluid and cleaned the pick up screen. This is the second time I have had to do this due to water getting in the system. The screen was completely gummed up with muck. I found crumbs on the screen of what looks like circuit board material I am guessing it might be brake material. I noticed that the linkage for the breaks was to tight causing the break to lightly engage at all times. I loosened the linkage and tested the brakes left side works as it should right side peddle oscillates up and down with the rotation of the wheel almost like a cam action. The right side works but you have to allow your foot to float up and down with the peddle in order to slow brake.
(1) How is water getting in the hydraulics.
(2) Thoughts on the brake
