crimsondad54
My John Deere 4120, is a 2010 with only 110 hours. The 4 wheel drive is getting hard to engage and disengage at times. It acts as if it is stuck or the lever needs greasing.
Once forgetting I did a fair distance in 4X and the wind up was so noticeable that I sheered a small roll pin that connected the lever to the shift shaft leaving me with only 2WD
On which JD was that?
All front wheels lead the rear by usually 5% or so causing build up torque. This is more apparent on paved or hard surfaces.
As the frt tires wear down the 'wind up' lessens. On grass and soil because some slippage occurs the wind up effect is less apparent.
The previous poster suggested one method to overcome this normal phenomenon but the best is to avoid 4X on hard surfaces unless slippage occurs.
In fact use in 2WD as much as possible keeping 4X for mud, hills and snow.
Personally I only travel in 2X and use 4X only plowing snow in winter or when stuck in mud.
Roy's suggestion is also good.
Once forgetting I did a fair distance in 4X and the wind up was so noticeable that I sheered a small roll pin that connected the lever to the shift shaft leaving me with only 2WD until I came up with a method to replace that wee roll pin without splitting the tractor as that 5 cent pin was inside the tunnel area between the transmission and clutch area.
(And naturally it was -25 deg at that time.)
