Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Apr 2008
    Posts
    11
    ohio
    john deere 2520
    Default 2520 blew the 1.5 amp fuse under the dash
    I just want to see if any owners of john deere 2520 have ever heard of this problem.
    I went to start tractor and turned key to glow and when I went to start I heard and small pop on the right side and the dash lights went out and no power what so ever. I have no headlights or flasher lights. Battery is full charge and no fuse in the box are blown,
    I pulled the dash off and there is a fuse wired with a plastic plug that is marked 1.5 and it checks bad, my question is what does this protect?
    I cant find anything on line and I dont have service manual I plan on going to JD to see if they know.
  2. #2
    Join Date
    Dec 2001
    Posts
    1,363
    Maryland
    Default Re: 2520 blew the 1.5 amp fuse under the dash
    I think you actually found a diode. There are 4 or 5 , depending on serial number, 1.5 amp diodes in the harness. If checking with an ohmmeter, they should show continuity in one direction but not the other.
  3. #3
    New Member
    Join Date
    Apr 2008
    Posts
    11
    ohio
    john deere 2520
    Thank you jd110,that makes more sense and it does still check bad, I still wonder what could have caused it to fail just time I guess.
  4. #4
    New Member
    Join Date
    Apr 2008
    Posts
    11
    ohio
    john deere 2520
    Problem ending up being a dead cell on battery that only showed under a load even though battery was fully charged it would drop to 3 volts when turned the key to start. The diode checked fine after I tested it again and most likely had nothing to do with issue but I still can't figure what the noise was when all this started.
Similar Threads
  1. 07 TC45DA 40amp Maxi Fuse blew (680 hours)
    By davidmr in forum New Holland Owning/Operating
    Last Post: 05-15-2013, 10:02 AM
  2. 273 dash cluster blowing fuse
    By tym_colorado in forum TYM Owning/Operating
    Last Post: 10-25-2009, 09:58 AM
  3. Dash Fuse Assembly Fell Apart?
    By vern6973 in forum Case-IH
    Last Post: 10-08-2009, 02:11 PM
  4. Key Stop Fuse Blew on 4240HST
    By JFD3940 in forum Kubota Owning/Operating
    Last Post: 05-20-2008, 07:51 PM
  5. Fuse number 5 blew on my TC33D
    By SteveInMD in forum New Holland Owning/Operating
    Last Post: 06-26-2007, 10:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
