V1BuzzBomb
Are John Deere backhoe quick tach buckets interchangeable between the 110 TLB and either/or the 35D and 50D mini Excavator buckets?
How do you like your Laurin cab so far? I have been satisfied with mine, 10 years old this week. Only problem I have had with it is the roof top spacers broke loose and I need to repair these when the weather improves. Otherwise mine is like yours with a top strobe and back up alarm.
Mine is sealed up tight with a factory provided bulb seal much like what is used around automotive doors. No problems with exhaust fumes.
Mine has the bulb seal as well. It seals okay but I do see gaps. The voids I speak of are inherent to the tank assembly of the JD110, visible dead center of images I post. Are yours plugged, open or...?
My cab came with two shaped pieces of clear lexan that I had to glue in those holes. Bet the dealer did not install them on your cab. I would plug the holes as I don't recall ever needing to see through the holes anyway.
The previous owner did the cab install. I believe I see the remnants of the glue there. Perhaps I'll contact Laurin for those. I also need a new heater blower switch connector shell and wiper blade refills anyway.
