Wondering if anyone has experience installing westendorf TA-55 loader on JD755. I've just received mine and got everything together but can't figure out how to hook up the in and out lines that feed the control valve on the loader. The folks at westendorf said the instruction were clear...but I find them pretty lacking in detail. I pulled the tech manual but just can't figure which of the ports will work. I've attached a picture of the valve under the seat of the 755 and the schematics from the manual. I don't know much about hydraulic schematics, and i'm not sure if i'm way off, but i thought one of the ports on this flow divider valve was where i needed to connect to. If anyone has some guidance, i'd appreciate it. thanks. I'll probably do a short write up with pics later since i found nothing like this on the forum.
loader on pallet
new control valve
pic of flow divider on right side
pic of flow divider on left side
loader on pallet
new control valve
