Mike_ONeill
Member
My John Deere 4310 blows the light fuse sometimes when either the 4-way flasher is used, or the turn signal (either direction.) /forums/images/graemlins/confused.gif
It doesn't happen if just the lights are on, without the flasher or turn signal.
It happens at random intervals of time. I once let the flashers run for an hour or so, then the fuse blew a few minutes later. Other times, it will blow within seconds of putting on the flashers. It's a 30 amp fuse. I even tried some 25 amp fuses. They didn't blow any quicker, but would work for a while, then blow out.
I had the dealer check this when the tractor was in for the hydro recall. They said they spent several hours on the fuse problem but couldn't make it blow or find anything wrong.
The fact that the turn signal blows the fuse regardless of which direction it is turned, suggests that the problem is not in the bulbs or the wiring to the bulbs.
Has anyone else had this problem? Any suggestions?
Thanks,
Mike
Thanks,
Mike
