axeman79
I'm looking for some advice on opening a 2955 hood. The operator's manual says that I should be able to remove the side screens and find a rubber latch (with ball) that will release the hood. It claims the hood can be opened without tools. My tractor had no such latches. The only thing I can figure that is holding the hood down are two nuts that hold the hood to the front plate. There is 1/4" rubber insulation between the hood and front plate and a narrow spot on each side of the hood where the nuts can be seen. I am assuming that I can turn the nuts and release the hood. I'm not sure if I will need to partially turn the nut to get a release or turn it completely off.
I've tried to attach a picture of the nut and bolt from the 2955 Parts Manual. The nut is part #11.
Is there someone here that has experience with this type of arrangement? Any advice regarding releasing the hood?
Chuck
Chuck
