marcin
I recently purchased a 1968 John Deere 5020. The tractor appears to start and run very well. I cannot change gears when the RPMs are high (>5000, i.e.: when tractor is not idling). I can hear and feel grinding and the gear will not engage. I imagine this is likely related to a used (up) clutch? Can any adjustment be made before it needs to be replaced? If so, is it through the cover plate underneath - I do not have a tool that is described to use here. Can the stop screw adjustment on the clutch pedal help with this also? I would appreciate any help. Thank you.
M
M
