eyalahav
- Joined
- Dec 10, 2015
- Messages
- 5
- Location
- Habonim, Israel
- Tractor
- John Deere 5400. Case 2290 (1983) Caterpillar D4 (1942)
The Tractor:
A John Deere 5400 Tractor, Serial No.: 5400542074 Engine Model 3029TLV01
Engine Serial No.: 3029247613 Year of manufacture: 1996. Made in USA. 9 Forward and 3 Reverse gears.
The problem:
While driving, the tractor stops spontaneously as if the brakes of both wheels where locked simultaneously.
There is a sound of 鼎LACK as if something Locked, the engine stalls and stops.
If the driver presses the clutch just in time to stop the engine from cutting out, without touching the gear lever, the driver can release the clutch and continue driving as if nothing happened until next time it suddenly happens.
Again and again.
The gearbox was opened and checked, no mechanical damage was found, no metal shavings found in the oil, or in the oil filter.
Can you help us solve this problem please?
My grandfather once had a Mule that did something similar, but grandpa he knew how to fix that.
Best regards, John Murphy, Engineering Services.
The problem:
Again and again.
