Toss the carpenter level.. as it helps none at all for what you need to do to get mowing "level".
As mentioned, air pressure the same in a tires (each side).
Locate on a flat surface.
Then raise the deck wheels so they don't contact the flat surface.
Set the height gauge at say 2"
Then with blades pointing straight out, measure and adjust the cutting edge to 2" (match the height setting of 2").
..... (Raise or lower so both right and left blade cutting tips are 2" by adjusting the hangers).
Then check the fore and aft height of the center blade and adjust so the front cutting edge is 1/4" lower than the rear.
..... (done by turning the nuts on the front bail that holds the front of the mower deck)
Finally, pick the cutting height you want to mow at and lower the four deck wheels so they clear the level surface by 1/4-1/2".
