sriddle1
- Joined
- Apr 2, 2014
- Messages
- 212
- Location
- SW New Hampshire
- Tractor
- ACTIVE: JDX730 DAYS GONE BY: JD3010, JD790, JD425
I own an '05 JD 790 Compact Tractor that resides in an attached garage. It smokes when you start-it-up (even when using the glow plug function) and that smell can creep into the house during the winter months + lingers in there for quite a while even with the stall door open.
The 790 has a short 45 degree angle 1-1/4 OD exhaust pipe above the front axle and situated just perfect to hit the rear of the 58 Front Mount Snowblower so the exhaust bounces back into the garage.
I've seen service bays use the Stainless Flex Tube/Hose to divert the exhaust outside. Looks like Walker Emissions Control (Commercial Line) makes a Galvanized Flex Tube in 6 lengths. Those familiar with a JD59 Front Mount Snowblower, they have Black Vertical Drift Blades attached to the sides of the Auger Housing. I thought I could Budgie Cord the Flex Tube to that, maybe? Either leave it permanently attached or when snow height is a concern, disconnect/remove when I get it running outside.
I have some questions not being mechanically inclined as you can tell by other postings. 1) I've read to avoid any Back Pressure, by adding a 6' extension would there be any concerns. 2) Not sure how to create a quick connect/disconnect over the JD exhaust pipe, don't want to break it off, vibration, etc. 3) Lastly, what diameter Flex Hose should I consider to ensure adequate flow, 6 lengths start at I.D. 2" to 6" but attaching & leakage would be a concern. Any thoughts appreciated. THANKS
