BufordBoone
Gold Member
I have a 1993 JD 2355 (came with the farm). The lift arms use a pin and bushing system. The pin is part number AR55695 - Lift Arm Pin. It is a pin with a plate welded on one end and a hole for a quick lock clip on the other end. A "strap" (square washer) also goes on it.
AR55695 - Google Search
I have been using this tractor mostly with the 10' (offset) bush hog (also came with the farm) since 2012. Last year I had one fail at the weld. I replaced it and the replacement also failed. I replaced that, asked the dealer to return the defective one to see if they would warranty it. They did. That was about this time last year.
Since then I pay close attention to those parts.
Today I had another failure at the weld. I've replaced that one with a spare but am getting tired of these things breaking. They are upwards of $20 each.
I found an affordable replacement online and have ordered one to see if it will work.
Anyone else having these problems with the Lift Arm Pins?
