I have a Deere 5045E that was running fine. I went to start it tonight and it cranked over, but the wouldn't crank after that. So, I started researching from starter back. Here is what I found. There is a 10 amp fuse that says starter relay that was blown. I put another one in, and when I turned key on, it blew before even trying to start. I took the relay in the fuse box out, replaced the fuse. When I turned on key...no blow, and it even attempted to start, but would only crank. I thought oh the relay is shorted. The neutral relay is the same type so I swapped them...it blew again. So I am thinking that something down the line is shorting it....any ideas?
Thanks in advance...this is my first post. I searched a bit but didn't see this issue. Will continue to search though.
tass.......
Some thoughts for you to consider.
In addition to engaging the starter, the relay may also interact with the fuel cut off solenoid allowing the tractor to receive fuel to the injectors. However, after reading your post again I am puzzled. You seemed to say that the starter engaged without the starter relay installed. Is this correct?
The fuel cut off solenoids have two electrical windings inside. A high current one to pull the solenoid plunger and a low current one to hold the plunger once it is pulled.
Can you locate this solenoid on your tractor's injection pump? Perhaps with your common rail system you dont have this component.
If you can, then disconnect the electrical connector for it and then see if your fuse still blows. The tractor wont start but should turn over.
How old is your tractor?
Do you have a wiring diagram you could post for us to study?
Later thoughts.
Your tractor is described as having an electronic common rail fuel system so my thoughts on the fuel cut off solenoid may not apply.
Newer tractor often have a diode in parallel with the starter solenoid to adsorb what is called a back electromotive force to be technical. A solenoid builds up a magnetic field around its coil and when the power to it is suddenly cut off, the collapsing electrical field can generate a very high voltage pulse of energy which can damage electronic components,
Has your battery been disconnected recently? Have you boosted the battery or connected a charger? Some of these done wrong can blow the diode and then you start blowing fuses.
These images show one of these diodes on another machine.
Note the diode symbol
Dave M7040
