bodin1968
i re-wired a JD 2020 tractor. ran all new wires from alternator to key switch and/or voltage regulator etc.... i believe i have all the wires configured correctly... however, i replaced the old tractor alternator jewel light with an LED light-- which will not shut off when the tractor is running??? The oil jewel light functions properly and it is a LED as well.
here's my question: Is that because the voltage does not drop low enough to shut the LED off? Should I replace with a regular bulb?
any suggestions appreciated. Thank n advance.
